586,032 active members*
2,962 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Circle cuts vary in size 20 mil along x axis
Results 1 to 6 of 6
    I have a commercial 2'x4' cnc with rack and pinion drive on X & Y. The machine cuts about 20 mil over size on the far side of the x axis whether its a 3" rectangle or 6" circle. Its close to spot on near x0. The pinion doesn't show wear and is tight against the rack. I've made sure the rack is straight with a straight edge. Checking the x axis resolution shows that it is spot on. Y axis doesn't appear to have this issue. Belt is tight.
    I've been cutting mdf for testing this with 1/4" bit, 1/8" DOC, just 50ipm feed at 12k rpm.
    What is possibly the issue? Some weird electronics problem?
    Jun 2005
    1730
    Re: Circle cuts vary in size 20 mil along x axis
    Check your stepper motor could be dragging or missing steps
    Quote Originally Posted by CNCMAN172 View Post
    I was hoping it would be as simple or easy as that but the error is positive and consistent with any feed speed. I am cutting at 50ipm at 1/8" DoC with a 2" length 1/4" bit. Cuts on the right side of the table are always ~20 mil larger than the left.
    Jun 2005
    1730
    Try to use a pencil in spindle and have it draw a circle without turning on the motor, just unplug power to VFD. This will let you know if you are getting EMI interference. If the pencil circle are perfect you have a noise issue
    Camaster said they would have to send someone out but its a two month wait. Twisted gantry.
    WTH causes a twisted gantry?
    Jun 2005
    1730
    Quote Originally Posted by KT88saturate View Post
    This could happen if you have two motors driving the Y axis, one on each side. If they get out of sync one motor can put too much force, but depending on the construction it would be hard to twist a strong gantry.
    Russ
  1. Does tool life vary with interrupted cuts to continuous cuts
    By acejunker in forum MetalWork Discussion
    Last Post: 08-08-2014, 02:34 AM
  2. keeping cuts the right size
    By vcazan in forum DIY CNC Router Table Machines
    Last Post: 07-27-2012, 03:30 AM
  3. weird circle cuts....cant figure it out!
    By johndjmix in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 05-24-2012, 01:42 AM
  4. circle cuts becomes ellipses??
    By nicanor76 in forum DIY CNC Router Table Machines
    Last Post: 10-26-2008, 01:02 PM
