587,671 active members*
3,439 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Circuit for converting 2-channel quadrature to single channel
Results 1 to 4 of 4
    Sep 2006
    177
    I need to convert a 2 channel (A and B phase) quadrature signal to single channel. The single channel should have double the frequency of the dual channel signals. Can anyone provide me with a circuit that does this?
    Dec 2003
    24220
    Re: Circuit for converting 2-channel quadrature to single channel
    Done all the time to increase the resolution to x2 or x4 by either using the the AB leading edges (x2) or both leading edges and trailing edges, (x4).
    Are you interested in doing it with TTL logic?
    Al.
    Albert E.
    Sep 2006
    177
    Yes. TTL logic
    Nov 2012
    1272
    A XOR B, which is SN7486. Or you can make your own XNOR gate with an SN7400:
    Attachment 347566
  1. USB Channel
    By ben_heinman in forum Fanuc
    Last Post: 05-02-2012, 12:55 PM
  2. encoder wiring channel A and channel B
    By senor J. in forum Gecko Drives
    Last Post: 12-13-2011, 04:30 PM
  3. 80/20 versus u-channel
    By SteveT44 in forum DIY CNC Router Table Machines
    Last Post: 11-19-2005, 11:39 PM
  4. IRC channel for EMC
    By Dan Falck in forum LinuxCNC (formerly EMC2)
    Last Post: 12-18-2004, 06:03 PM
  5. Two steppers from one channel?
    By m1911bldr in forum CNC Machine Related Electronics
    Last Post: 03-30-2004, 03:30 AM
