Hi!
I'm using Edgecam 2012 R1.
I can not deal with a problem, could you help me?
Created profile (rectangular with filled), wrapped it on cylinder, in manufacture mode selected radial mill (driven, ballnose, D2 mm) and perfomed slot cycle. Then generated code. For this operation Edgecam using Сylindrical Interpolation (G107, CZ-moves), but instead circular interpolation (G2/G3) generated linear moves (G1) with accurate approximation, given in a cycle. Occasionally it is generated by the radius, but I can not figure out when this happens because the file and post-processor are the same. How to make the output is always radius and what determines how to generate the circular sections? If necessary, I can attach files *.ppf and *.cgd.
Below are two different codes (in zip), that generated by one postprocessor from one file.
P.S. Sory for my bad english.
