603,943 active members*
3,384 visitors online*
IndustryArena Forum > CAM Software > UG NX > Circular output in milling
Results 1 to 18 of 18
    Jan 2008
    63
    Hi all, Using Nx4.
    Please have a look at attached file. My part is perfect circle and i want to finish it by z-level profile option. But when i post the program what i get is a series of quadrant movements and not a full circle movement. The problem is i am getting a small recedue at the point where the quadrant movement ends. its not acceptable. is there any way that i can get a full circle movement. For your info in post my circular motion is set to FULL CIRCLE option.
    I am pretty sure that this has something to do with LOOK AHEAD of the machine as well but i need a strong arguement to explain it to our workshop supervisor who believes the machines we have are the best.
    Thanks and Regards
    Attached Files Attached Files
    Ananth Kulkarni
    THE GREATEST OAK WAS ONCE A NUT WHO HELD ITS GROUND
    Feb 2007
    664
    is the cut smooth or does it pause at the quadrant points ?
    if the cut is smooth what you are seeing is the backlash from the axis reversal at the quadrant point
    Jan 2008
    63
    Thanks for your comments.
    Yes the cut is smooth. its not stopping at quadrant point.
    Pardon me, if you can explain me about backlash from axis reversal? why it happens? because of old machine and worn out lead screw?
    Ananth Kulkarni
    Feb 2007
    664
    Quote Originally Posted by blmmdes View Post
    yes a worn machine will have some backlash
    what wears is the ballscrew assembly , the bearing blocks for the screw and the machine ways
    on most machines you can compensate for the backlash
    first you need to check the amount of backlash you have
    use a 1 inch dial indicator mount it on the table parallel to an axis jog it to touch the spindle ,zero it out step in 0.01 ten times then step back ten times and compare the position of the indicator from the start
    the difference will be the backlash for that axis ,do it several time to come up with an average
    adjust the comp in the control and repeat for each axis
    this will get rid of most the backlash
    you will still see some dwell mark from the axis reversals but they should be less
    also if you axis are belt driven the belts could be worn
    Jan 2008
    63
    I got an average value for backlash. How do i tell my controller about this? You said "adjust the comp in the control"
    Where actually i can do this? and how
    Ananth Kulkarni
    Feb 2007
    664
    what control do you have
    Jan 2008
    63
    FANUC
    Ananth Kulkarni
    Feb 2007
    664
    you will have to ask someone that knows that control
    sorry i can't help you with that
    Jan 2008
    63
    OK THANKS FOR THE HELP SO FAR
    Ananth Kulkarni
    Jun 2007
    65
    FANUC
    How much backlash do you have most of the time it will be in the thrust bearings.
    What # Fanuc control do you have.
    John
    Mar 2007
    137
    Command John is correct! most of the time the backlash IS in the thrust bearings. If you have anything over .0015 of backlash, you can't comp for it, and make your cut perfect, so say the hardcore mold cutters! put an indicator on the end of your ball screw and see if its moving, while you jog back and forth, that will tell you where the bear **** in the buckwheat....MY GOD, i'v been hanging out with old people to much!
    Jan 2008
    63
    Its Dialog 11
    Sorry friends,
    Its not fanuc control its a Dialog11 from Grundig. I have a backlash of 0.015mm on X and Y axes. Now the question is how do i compensate for it in the controller? is there any parameter that needs to be changed? if yes, which parameter?
    Thanks in Advance
    Ananth Kulkarni
    Jun 2007
    65
    Not bad but I can’t help with that control.
    John
    Apr 2008
    23
    The Dialog has a direct measurement so
    it cannot compensate for backlash and
    it is not necessairy. This is a very precise
    system usually and it will automatically
    compenate for any backlash in the ballbearings
    and ballbearing nut. That is because the
    direct measurement is on the same location
    of the spindle.
    But if you have backlash in your X or Y guides
    then you will have non precisie circles as
    the direct measurement won't compensate
    for that. You can adjust this with the tapered
    keys that adjust the clearance in X and Y.
    Be very carefully not to adjust it too tight as
    this will cause even more problems. Just try to to tighten the tapered keys a little bit and see the effects, do it in very little steps and write down
    the results. Let me know if you have any improvement. Mail me on [email protected]
    I have done this myself and have seen some
    improvement on our Deckel FP4NC but this was not with circels.
    Jan 2008
    63
    That was useful information Ricard. Thank you. I will try your suggesion CAREFULLY and post the results in this forum.
    Ananth Kulkarni
    Apr 2008
    23
    The easiest thing to check is to up and
    down the X for example 0.05 and -0.05 and measure if your total displacement is zero after this movement. If not, this is your backlash and
    you can check the tapered keys which can
    cause this.
    You also have to do this for Y.
    If you cut a circle you should cut very
    few while finishing.
    What machine do you have there?
    this forum.
  17. #17
    Jan 2008
    63
    i have a twin brother of yours. Deckel FP4A
    finding out the amount of backlash is clear.
    But
    "If you cut a circle you should cut very few while finishing" what do you mean by that can you please explain.
    Ananth Kulkarni
  18. #18
    Apr 2008
    23
    Sorry for my bad english.
    For example, cut only 0.1 mm and have
    a feed of 0.03 mm/revolution/teeth if
    you have a sharp mill. What I just mean
    is to not cut for example 2 mm if this
    is the last cut.
    For our machine from 1984 the backlash
    is only about 0.003 mm in both X and Y.
    As you have a Dialog 11 which is much
    newer it should be less.
    But
  1. What do you know about this circular saw???
    By mailloux in forum WoodWorking Topics
    Last Post: 10-17-2007, 04:34 AM
  2. mazak 640m circular tornado milling cycle
    By magneto259 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-20-2007, 06:03 PM
  3. Circular Cut
    By Sanghera in forum Uncategorised CAM Discussion
    Last Post: 11-13-2006, 05:26 PM
  4. Milling 37 degree chamfer around a circular piece...
    By peter.blais in forum MetalWork Discussion
    Last Post: 09-20-2006, 06:47 PM
  5. Circular Milling - G12/G13
    By HPT in forum Servo Motors / Drives
    Last Post: 05-14-2006, 07:22 PM
