603,335 active members*
3,797 visitors online*
Results 1 to 4 of 4
    Sep 2005
    29
    Citizen E20 OVERSIZE BORE...?
    Hi guys, I'm about to purchase a Citizen E20 (screw machine) made in 1990, now i no you can go to 32mm from an E25 but can you go to 25 or even 32mm with an E20 machine...? The machine is at auction and it ends Monday so any info asap would be appreciated, we do a lot of 7/8 (22.225mm) work so its an important factor on the machine purchase.
    Many thanks
    gollame
    Jan 2005
    304
    I do NOT know that model but on ALL the other Citizen machines the smallest diameter that must fit over your bar is 1mm over the machine size. That means on a 20mm machine you will have to be less than 21mm without altering anything.
    Feb 2008
    267
    In the US, I've never heard of an E20 ... 16/25/32 but in UK i'm not sure.
    That said, I have heard of people getting L20's up to 7/8" stock with modification.
    Not sure if it's possible on E.
    Good Luck.
    Sep 2005
    29
    you can
    Hi and thanks for the replys, i don't think these went to the States though there may be one or two of them over there, the answer to my question was yes....! a conversion kit costs £1000 UK Pounds and will go to 25mm (1 inch)
    and thats it limit so thanyou all
    cheers
    gollame
  1. Citizen CAV barfeeders
    By EdgeCrusher in forum CITIZEN Machines
    Last Post: 09-26-2017, 12:51 PM
  2. pick off on citizen f12
    By cseely in forum CNC Swiss Screw Machines
    Last Post: 01-09-2008, 06:13 PM
  3. DPRNT on a Citizen with a L25/32 CONTROL
    By mistux in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-20-2007, 09:26 PM
  4. How to operate a Citizen FL-42
    By Twistr in forum Uncategorised MetalWorking Machines
    Last Post: 12-28-2006, 12:23 AM
  5. Milling with a Citizen C16
    By Koalas in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-22-2005, 08:22 AM
