587,680 active members*
3,561 visitors online*
IndustryArena Forum > MetalWorking Machines > CNC Swiss Screw Machines > Citizen L-25 inconel 600 drilling
    Dec 2012
    13
    I have a part coming up that has a .900 deep .154 diameter hole. It has a .0005 concentricity callout between 2 outside diameters. One of the dia is only .004 smaller than stock size. I always have problems with material swelling and putting conc. to .002-.006. I am using G821 to keep material as close to guide bushing as possible. Drilling is done first so that it is supported by guide bushing. Any tips for a good drill or method to help this? Cycle time is exrtremely critical. Thanks
    Jan 2011
    44
    material is swelling-stretching:
    turning to fast
    drilling to fast - tool gets hot, do not make tools and material hot
    concentricity:
    check your bushing for run out. use test indicator.
    try indicate of off sub, drills of off bushing it self.
    use cutting oil Hard Cut 1854
    ANY WAY TRY THIS.
    T2200(DRILL)
    G0Z-.05T22
    G65P1212A.2B.1C.05Z1.W.01S-.05R-.05F.001D.3E2
    G0Z-.05T0
    play with feed rate, A, B, C,D, E
    MICRO
    $1
    O1212
    #140=#4001(SAVE-GO-G1)
    #141=1(SET-DWELL-COUNTER)
    IF[#7NE#0]GOTO1(CHECK-DWELL)
    #7=0
    N1IF[#24NE#0]GOTO105(CHECK-X)
    IF[#26NE#0]GOTO5(CHECK-Z)
    #3000=1(X OR Z IN COMMAND LINE MISSING)
    N5(Z)
    IF[#23NE#0]GOTO6(CHECK-W)
    #3000=1(NO W ON COMMAND LINE)
    N6#23=ABS[#23](MAKE+)
    #139=1(SET PECK COUNTER)
    #142=#19(142=Z POS EACH PECK)
    N8G0Z[#142-#23]
    #142=#142+#[#139](ADD ON EACH PECK #1-#2-#3-#3)
    N10IF[#142LT#26]GOTO20(CHECK IF DONE)
    #142=#26
    GOTO100
    N20G1Z#142F#9
    G0Z#18
    IF[#141NE#8]GOTO30
    G4U#7
    #141=0
    N30#141=#141+1
    IF[#139EQ3]GOTO8(NEVER GT 3)
    #139=#139+1(COUNTER FOR #1-#2-#3)
    GOTO8
    N100G1Z#142F#9
    G0Z#18
    G#140
    M99
    N105(X)
    IF[#21NE#0]GOTO106
    #3000=1(NO U ON COMMAND LINE)
    N106#21=ABS[#21]*2
    #139=1
    #142=#19
    N108G0X[#142+#21]
    #142=#142-[#[#139]*2]
    N110IF[#142GT#24]GOTO120
    #142=#24
    GOTO200
    N120G1X#142F#9
    G0X#18
    IF[#141NE#8]GOTO130
    G4U#7
    #141=0
    N130#141=#141+1
    IF[#139EQ3]GOTO108
    #139=#139+1
    GOTO108
    N200G1X#142F#9
    G0X#18
    G#140
    M99
    (CALL BY)
    (G65P8999A.15B.1C.05R-.05S.3Z1.5W.02F.001D1.E2.)
    (G65P8999A.1B.075C.05R1.1S1.X0.U.02F2.D1.E2.)
    (A=#1 FIRST PECK IN RAD.)
    (B=#2 SECOND PECK IN RAD.)
    (C=#3 THIRD AND ALL THE REST PECKS IN RAD.)
    (R=#18 RETREAT POINT)
    (S=#19 START POINT)
    (Z=#26 X=#24 ENDING POINT)
    (W=#23 U=#21 RAPID RETURN DISTANCE FROM LAST PECK IN RAD.)
    (F=#9 FEED)
    (D= #7 DWELL IF NOT THERE NO DWELL)
    (E=#8 DWELL EVERY? PECKS)
  1. Drilling Inconel 718
    By MountNebo in forum MetalWork Discussion
    Last Post: 06-07-2012, 10:43 PM
  2. Gun Drilling on Citizen Swiss Turn
    By SwissBeast in forum CNC Swiss Screw Machines
    Last Post: 12-28-2011, 03:55 PM
  3. Drilling 1.812 hole in 625 inconel
    By wayne623 in forum Uncategorised MetalWorking Machines
    Last Post: 10-25-2011, 08:59 PM
  4. inconel 710
    By jaimeoro in forum RFQ Feedback
    Last Post: 03-24-2009, 07:25 AM
  5. Drilling Inconel
    By mmiranda in forum MetalWork Discussion
    Last Post: 01-16-2009, 09:58 PM
