587,777 active members*
2,877 visitors online*
IndustryArena Forum > MetalWorking Machines > CNC Swiss Screw Machines > CITIZEN Machines > citizen L20 programming help! tool nose comp
Hybrid View
    Jan 2014
    3
    hey there gang!
    im trying to program the part below.
    Attachment 391858
    and im having a difficult time with the tool nose compensation as im using a full radius insert like this (.125" width, .0625"r):
    i did the math and have figured out my start and end points of all 3 radii but i keep getting an alarm that the tool is interfering with tool path. do i need to change the compensation from left to right in the middle of the deep radius? or is there a way to tell the machine that the insert is full radius?
    thanks in advance for your help!
    Apr 2017
    7
    Re: citizen L20 programming help! tool nose comp
    I would suggest you direct program it without using cutter comp, or direct program it and comp it a R0 P8 if you need the radii adjustment.
    You can program it using cutter comp with the tool radius in your R value, but you will need to switch the cutter comp quadrant (your P value in T-data, variable #23xx where xx is your offset number) in the middle of the cut and also workshift to the other side of the insert at that time. Looks like you would have to switch your P and workshift 3 times for turning this feature (at the top/bottom of each radius of your 3 radii).
    Remember, cutter comp only correctly comps in a 90° angle (45° each side) from where your tool tip is pointed (determined by your P value), except when P0. In your example, you would be using almost 180° of comp.
  1. Tool nose comp
    By jorgehrr in forum G-Code Programing
    Last Post: 09-26-2010, 07:23 PM
  2. tool nose radius comp
    By joe1970 in forum G-Code Programing
    Last Post: 02-25-2010, 04:43 AM
  3. Tool nose comp for Fanuc OT?
    By Bobesmo in forum MetalWork Discussion
    Last Post: 12-30-2009, 11:48 PM
  4. tool nose comp?
    By wronggrade in forum G-Code Programing
    Last Post: 12-02-2008, 01:46 PM
  5. tool nose comp.?
    By pp-TG in forum MetalWork Discussion
    Last Post: 09-19-2006, 09:36 PM
