603,982 active members*
2,505 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Clarification needed on current limiting resistors
    Aug 2003
    75
    I've done all the math and understand the wattage & ohm ratings of what I'm going to need and require for my particular senario... but the doc's I have with my board, and what I've read and seen online suggest that the current limting resistor should go on the + pwr legs for each stepper. I would think that you'd want to have the current limited at the feed to the board to reduce the excess current, so it doesn't cause uneccessary heat. Am I way off base here ? or has anyone else thought along these lines ?
    Then again it could just be a case of extreme dislexia, and that's how I should have had them configured to begin with..... duh...
    thoughts, suggestions ?
    thanks guys,
    Arthur
    Aug 2004
    2849
    Quote Originally Posted by ccm
    thanks guys,
    Arthur
    Arthur, it a circuit...so as long as the resistor is in the circuit it will do it's job.
  1. Calculating current limiting resistors (I need serious help)
    By Konstantin in forum CNC Machine Related Electronics
    Last Post: 07-25-2005, 10:10 PM
  2. Current limiting resistor
    By pyrojon in forum CNC Machine Related Electronics
    Last Post: 04-20-2005, 02:47 AM
  3. Motor calculations
    By jevs in forum CNC Machine Related Electronics
    Last Post: 03-21-2005, 08:05 PM
  4. Clarification Needed - (warning Noobie content )
    By ccm in forum CNC Machine Related Electronics
    Last Post: 11-09-2004, 06:35 PM
  5. Current limiting on homemade driver
    By MrBean in forum CNC Machine Related Electronics
    Last Post: 10-22-2003, 09:02 PM
