Check these out. Very cool.
http://www.dyengineering.com/
http://www.machsupport.com/forum/ind...topicseen.html
Gerry
UCCNC 2017 Screenset
Mach3 2010 Screenset
Looks like a good design, & very low price.
Free DXF - vectorink.com
Interesting find Gerry. Someone has been busy.
That design looks good. I wonder if it will keep water and dust out though.
Toby D.
"Imagination and Memory are but one thing, but for divers considerations have divers names"
Schwarzwald
www.refractotech.com
It might keep dust out, no way on the water tight seal, If anything it would hold water.
Very nice, I could use these. I am going to re-wire my machine in the next few months and may use these. I wonder if a provision for hand wheels and dampners could be made?
Necessity is the mother of all invention (unknown)
My club home page www.lhmac.org
This is nice! I always hated the way my wiring looked at the motors. This is something I will definitely get on my next build.
That's a must have now! Thanks for the link. Installation looks like a breeze too.
http://www.keepandshare.com/doc/view...d=1541519&da=y
I was quite surprised by the price, expected it to cost more considering the shape.
The only gripe I have about this design is that it stops you from using a rate damper on the back of the motor. Having said that it's nice for those with Gecko's and wasted space where the second shaft is.
Having said that, for an even neater look it may be worth opening the motors, de-soldering the standard cables and replacing it with your own shielded round cable. Although it depends on your ability to solder and to open a motor without breaking it.
Website.
Gerry
Hi Guys,
Thank you for the compliments. Sorry for not visiting this forum more frequently. I am mainly on the Mach forum and the Yahoo group.
Making a version to take handwheels is in the works. Will be selling them with an extension shaft. Working on the sealing of the hole around the shaft.
Also a version with a gasket and a gland will be available for a full sealing. Using a sealed connector is a problem since these connectors cost more than the cover itself. I may be offering it as on option though for an additional cost...
Gerry, thank you for posting the links here for me
Thanks,
Daniel
Just a note, that most if not all Keling steppers over 282oz are not Standard Nema23 size, but are actually 60mm cases, and these covers will not fit them. Be sure to measure your motors.
Gerry
Note: the following Keling Stepper which is intended for use with the Gecko G540 at 18VDC to 50VDC is standard Nema 23 size.
KL23H2100-35-4B (1/4” Dual shaft with a flat) 381 oz-in
These covers are a great fit. Use a little high temp silicone (from the auto parts store) to seal them up. Seal the cable at the connector cord grip with a little silicone. These are excellent products and I would recommend them to anyone wanting a sealed motor. You should also look at a front shaft seal, but if the front shaft is covered it may not be required. Depends on how much splashing is going on inside your enclosure.
Thanks David for a great product.
Hi guys,
Thank you for your kind words about the covers.
Wanted to let you know that a new stock of these with a slightly improved design is available now on my website www.DYengineering.com
There is also an option with an O-ring and a cable gland available for a completely sealed assembly.
Also, covers for the 60mm motors are in the works now and should be available soon.
Thanks,
Dan
Excellent looking product and like others mentioned, I hate the look of sloppy wiring! I ordered 3. I am sure I will be back soon.
Fastest1, thanks for your order and kind words. Will send out your order tomorrow morning.
Daniel
What a cracking idea! solves a few niggly problems in one move.....My order just went in... Cheers Ger! :cheers:
Keith
