588,525 active members*
7,742 visitors online*
Results 1 to 5 of 5
    Aug 2005
    93
    Cleaning Granite Surface Plate?
    Is it alright to use paint thinner (mineral spirits) to clean up the marking on a Granite Master Surface?
    Cool
    It will not hurt the rock, but the best cleaner is GoJo non abrasive hand cleaner!
    www.widgitmaster.com
    It's not what you take away, it's what you are left with that counts!
    May 2005
    2502
    Starret makes a surface plate cleaner that isn't very expensive and works extremely well. Also, keep 'em covered. Mine picked up an amazing amount of debris until I got a cover for it.
    Best,
    BW
    Feb 2005
    376
    I've found that some soap and water, then finish off with Acetone leaves a nice non oily, non sticky surface that the height gage just glides around on.
    rubbing alcahol
