588,084 active members*
4,821 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Clearance / Feed plane - Absolute/Incremental
Results 1 to 6 of 6
    Oct 2009
    77
    Trying to understand this concept
    Let say I have a rectangle and using a contour toolpath. I place 5 inches for clearance plane in absolute and 3 inches for feed plane in incremental. I am thinking that would not matter what I use absolute or incremental because I have only one rectangele. However, it would matter if I have one or more chain in the toolpath, correct ?
    Dec 2008
    3136
    No,
    It would depend upon where( in the Z plane ) the shape was drawn
    Absolute Z values are in respect to the WCS origin
    Inremental is in respect of the shape
    Eg. 1 rectangle at Z2. and 1 rectangle at Z-2.
    Clearance = 5" (Abs)
    Retract = 3" (Abs)
    Feed plane = 0.2 (Inc)
    Top os Stock = 0 (Abs)
    Depth = -1. (Abs)
    your paths are to start feeding into the shapes at Z0.2 and finish at Z-1.
    Both rectangles will start / finish at the same Z plane
    But
    Retract = 3" (Abs)
    Top os Stock = 0 (Inc)
    Depth = -1. (Inc)
    your paths are to start feeding into the #1 shape at Z2.2 and finish at Z1.
    and #2 shape feed in at Z-1.8, bottom will be Z-3
    Oct 2009
    77
    Sorry for my ignorance but I'm trying to understand the second example. How do you get a value of Z-3 ?
    Dec 2008
    3136
    Because you told mastercam that the final cut-depth is to be 1" below the shape ( Depth = -1 increm )
    Remember, the shape you select controls the Zplane when incremental is used
    Try using incremental, and regen a toolpath, then lift only 1 of the chains.
    Your toolpath will go dirty, regen it again and only the toolpath on the moved chain will be modified.
    Oct 2009
    77
    Thanks for the response.
    Feel like an idiot, its all starting to make sense !!
    Dec 2008
    3136
    Be prepared to feel that way for a long time,
    There's a lot to learn :drowning:
  1. Incremental Vs Absolute mode
    By chilly2k in forum Mach Wizards, Macros, & Addons
    Last Post: 03-06-2009, 11:54 PM
  2. Subroutine and Absolute/Incremental
    By VWbmx in forum G-Code Programing
    Last Post: 02-22-2009, 08:09 PM
  3. Offsets: Changing between absolute and incremental
    By MotorCityMinion in forum Haas Mills
    Last Post: 03-04-2007, 05:57 PM
  4. Absolute or Incremental
    By mikede in forum Haas Mills
    Last Post: 02-04-2007, 12:02 AM
  5. Absolute and Incremental
    By ACME in forum G-Code Programing
    Last Post: 09-04-2004, 11:45 PM
