603,411 active members*
3,845 visitors online*
Results 1 to 12 of 12
    Jan 2008
    3
    clipping a thread
    Need some help. Do all my threading on a G92, does anyone know an easy way to do a clip? Controls are Fanuc 21i-tb, on a l&l45-80 lathe. Thanks.
    Jan 2005
    304
    Gotta ask
    What is "Clipping a thread"?
    Jun 2007
    3738
    Question Ditto.
    Super X3. 3600rpm. Sheridan 6"x24" Lathe + more. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
    Jul 2005
    12177
    Quote Originally Posted by neilw20 View Post
    Different name for a Higbee cut?? An abrupt start that takes away the feather edge at the beginning of a thread.
    Jun 2007
    3738
    Smile Who was Higbee?
    Thanks Geof.
    Never too old to learn a new name.
    Nov 2007
    188
    higbee cut
    Try the link below I ran across it the other day talks about using a G32 to do the higbee cut
    http://www.practicalmachinist.com/vb.../t-121785.html
    May 2007
    1003
    Blackbird, I thank you for the question, and thanks to the others for their replies. I learned something new today...always a pleasure. Now I will have to give it a try myself. :wee: We do lots of threading, but never had a call for this type of thread.
    Sep 2003
    64
    Can use same thread cycle. Just move your start point over 1/2 lead and shorten thread length. You can actually use a regular turning tool or I like to use grooving insert for the thread cycle on the higbee.
    Jan 2008
    3
    Thanks for the replies. We ended up using a groving tool to do it. Worked not to bad. I will look into a G32 to see if it will work. Moving the thread over 1/2 a pitch was what I wanted to do, but we weren't sure that was what the blueprint called for.
    May 2007
    1003
    Quote Originally Posted by 91blackbird View Post
    Mind telliing me what RPM you used? I tried it on a thread running at S1500 and it took 3/4 of a turn to pull out. Not acceptable! It seems to me that this would work only at very low RPMs. Rapid on our Daewoo is pretty fast. Fast enough that I always flip the switch to 50% for manually moving the turret.
    Thanks.
    Jan 2008
    3
    I think the rpm we used was 200, same speed as threading.
    Feb 2008
    40
    All turning centers are going to rapid at different ipm's depending on year, make, model. I find that 50 rpm is good because You can offset your grooving tool on the X axis and it is turning slow enough that you can watch where it is on the Z axis and make your adjustments there.
    Or if you aare just backing the start position off half the pitch, keep in mind that regardless of what the Z offset may be on the grooving tool it must be exactly the same as the threading tool, doing this makes a more repreatable program, just inform your operators.
  1. MY X3 Thread
    By bryanrabb in forum Benchtop Machines
    Last Post: 01-14-2008, 06:58 PM
  2. Min Thread?
    By pp-TG in forum Mechanical Calculations/Engineering Design
    Last Post: 12-17-2007, 04:09 AM
  3. Thread
    By brtlatjgt in forum Solidworks
    Last Post: 09-13-2007, 03:14 AM
  4. hey. where did my thread go
    By fastimes in forum Waterjet General Topics
    Last Post: 08-26-2006, 05:15 PM
  5. New Thread
    By Redline in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 08-17-2006, 08:25 PM
