Closed Loop CNC Linear Scale Integration
Project
Adapt a linear scale DRO system for use as a CNC closed loop positioning system. This has been done previously and claims are out there of an appealing 60% increase in machining accuracy versus an open loop encoder driven positioning results.
Scale form used in testing will a GRID measurement technology with added truing or reset points in course of travel. GRID is a line marked media strip using up to a 100,000 marks per inch; a sealed glass scale in this case. Scale resolution is 1um or 0.001mm which matches closely too servo tick count of 40 to 50 millionths of an inch.
Machine form is a Standard RF45 mill/drill with an Industrial Hobby CNC retrofit kit.
Looking for comment or thoughts on project! I have ability too have DRO system modified as needed!
Ken
Kenneth A. Emmert
SMW Precision LLC
Spokane, WA
866-533-9016 Toll Free
