586,630 active members*
2,521 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Chinese Machines > CNC-3018 quit communicating when the spindle motor energized
    Mar 2021
    35
    Here is a short clip demonstrating the issue I am having (New machine )
    https://www.youtube.com/watch?v=X74qHXsysJ0
    If I remove the power from the spindle motor, the cnc will not lose communication and will operate and move in all three axis in accordance with the G-code. The communication loss only occurs when the spindle motor is energized.
    What I have done so far
    1-I separated the power supply of the spindle nmotor from the control
    Still the same issue
    2-I de-attached the control board from the machine frame to rule out vibration and electrical noise
    Still the same problem
    3-I de-attached the spindle motor from the frame away from the machine and carfully hold it with my hand and supplied power to it
    in this case the machine operated and executed the g-code file
    So it seems that this issue only repeat when the spindle motor is attached to the frame where it should be.
    Philip
    Mar 2021
    35
    Re: CNC-3018 quit communicating when the spindle motor energized
    It was a stupid data cable
    That should have been the first thing I should have suspected.
    Anyway I wanted to report the solution. If that help someone that may come across the same situation, I will be glad.
    Philip
    Sep 2018
    20
    Thanks for posting Philip
  1. 3020 spindle quit working.
    By Scrappy1 in forum Chinese Machines
    Last Post: 01-15-2015, 08:56 AM
  2. KL4030 quit - motor justs chatters in place
    By thegeekineer in forum Automation Technology Products
    Last Post: 01-29-2014, 06:52 PM
  3. 2.2kw water-cooled spindle smoked then quit!
    By TheProCreator in forum DIY CNC Router Table Machines
    Last Post: 11-29-2010, 06:13 PM
  4. Syil Spindle has quit working
    By marco928 in forum Syil Products
    Last Post: 03-16-2010, 07:01 AM
  5. Spindle quit running w/ c axix fault
    By TomCNC88 in forum Fadal
    Last Post: 07-28-2006, 04:07 PM
