603,373 active members*
3,746 visitors online*
Results 1 to 9 of 9
    Nov 2013
    7
    I purchased this cnc on ebay and I know what you all will say..its crap and throw it away. But im a hobby wood turner and this machine was mainly used for engraving pen boxes and thats it... well 4 months into owning it the z axis just stopped going up and down. The motor hums but doesnt move. I contacted the seller and.was.blocked without help. Go figure..
    List if things I have done
    Switch z motor with x axis motor and issue stayed at z axis telling me the motor is good.
    Checked the wiring for connectivity will multimeter and all wires are good.
    Control board? Has anyone had this issue and.fixed it with replacing a component?
    I dont want to buy a new.control board if I dont have to as I use this very rarely and would just break the bank.
    Attached Thumbnails Attached Thumbnails 20140413_221153.jpg   20140413_221216.jpg
    May 2014
    28
    Re: cnc 3020 z axis issue
    You already know which of 4-pin male connector on the board is for the Z-axis, trace which driver IC it's coming from and replace the faulty stepper driver IC.
    Nov 2013
    7
    Quote Originally Posted by cnzrepair View Post
    I didnt even think of that. I just ordered a whole new driver board. Probably better with spindle control and 4 th axis for future
    May 2014
    28
    I hope the 4-axis version has better thermal management. Your picture of the older driver board has the driver IC poorly mounted on the case. There are 4 screws holding the 3 driver ICs and the one closest to the front has the mounting hole towards the back barely making contact with the screw. There is probably not enough pressure to provide good thermal contact with the case which lead to the original failure.
    Nov 2013
    7
    Im now tempted to fix this board and redo the screws...
    May 2014
    28
    Driver ICs cost like $5 off eBay, you got nothing to loose at this point and end up with a spare drive that might me more robust than the original. Add thermal paste to the IC's heat spreader while you are at it.
    Nov 2013
    7
    Thanks for the tips... with the origional board I wont have to figure out the motor pin outs since there is no diagram on these lol
    Nov 2013
    7
    Thanks fir the help. It works great now...
    May 2014
    28
    Congrats! Glad to hear it worked for you.
    Quote Originally Posted by RusDemka View Post
  1. CNC 3020 X axis turning both ways when only requesting one in Mach3
    By navnavnav in forum Mach Software (ArtSoft software)
    Last Post: 09-10-2013, 09:54 PM
  2. 4 axis issue
    By JPowell in forum Mach Mill
    Last Post: 10-13-2011, 08:09 PM
  3. VMC 3020 Axis would not move
    By zecevic in forum Fadal
    Last Post: 08-22-2011, 01:11 AM
  4. VA-50 Z axis issue
    By DragonRider in forum Mori Seiki Mills
    Last Post: 01-14-2011, 04:04 AM
  5. Z Axis issue
    By ranchak in forum Bridgeport / Hardinge Mills
    Last Post: 11-30-2010, 06:28 AM
