587,213 active members*
3,379 visitors online*
Results 1 to 4 of 4
    Jul 2013
    7
    CNC 6040 Spindle Won't Stop
    I've had my machine for over a year and half now with little to no problems.
    Just the other day i was running a job - and accidentally set my z level too low and in the middle of the job, the bit hit the bed and snapped. Ugh.
    The strange thing is, the spindle won't stop spinning now. Even when i turn the manual speed control up and down and try to switch off the spindle on the control box. I've tried shutting everything down, including the computer, and rebooting. No help. Tried disconnecting and reconnecting the spindle motor. No help...
    Anybody else experience the same issue? What may have gone wrong, and how do i fix it?
    Sep 2015
    Re: CNC 6040 Spindle Won't Stop
    Have you been able to fix it? My machine started doing the same thing today after I went too low, and the collet hit the top of the stock.
    Feb 2016
    5
    Quote Originally Posted by Petrichor View Post
    Same machine, same problem.. Did either of you work out a fix?
    Feb 2016
    5
    Quote Originally Posted by Flaschard View Post
    OK - Uninstalled Mach3 and re-installed. Problem solved.
  1. CNC 6040 VFD/Spindle problem...
    By m_thread in forum Chinese Machines
    Last Post: 03-02-2021, 08:59 PM
  2. fresh Stepmores 6040 won't start spindle
    By hellryder in forum Chinese Machines
    Last Post: 12-04-2014, 10:16 PM
  3. Machine stop / Spindle Stop with a Dwell
    By yaji63 in forum Fanuc
    Last Post: 02-16-2014, 06:49 PM
  4. Replies: 10
    Last Post: 12-21-2013, 09:11 PM
  5. CNC 6040 VFD spindle control
    By rthorntn in forum LinuxCNC (formerly EMC2)
    Last Post: 09-29-2011, 09:23 AM
