603,940 active members*
2,758 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Chinese Machines > CNC 6040 - X-Axis stutters and Jitters when moving x-, x+ is fine
Results 1 to 6 of 6
    Aug 2020
    6
    Question CNC 6040 - X-Axis stutters and Jitters when moving x-, x+ is fine
    Hello,
    This is my first post and "hi everyone".
    I recently started with milling machines (again.. its been 20 years ago and i aint had problems,.. just Carbon cutting) - but i am more a FDM - SLA - mSLA guy.
    Anyway
    Pre Problem : I bought a CNC 6040 which is chinaware from a german warehouse - aside from that it seemed to be a used one i was quit happy except the Y-Axis which is not stiff enough (not railed).
    When i started the first milling trys on MDF i noticed that several things happen and can be reduced to the same problem:
    Problem 1: Multilayer Carving - the second and third layers are always shifted between 1 and 2 mm to the right.
    Switched X and Y Axis and the problem persists - so its shifting upwards about 1-2 mm.
    I read it might be a defective driver - well.... tell me ?
    Problem 2:
    Z-axis does start to stutter/Jitter SOMETIMES when moving down - sounds it like skipping steps (same as you would hear when watching the video - but more seldom but heavier.. and you see the handwheel jumps)
    What RALLY makes me wonder is: Jog Movements or using Arrow Keys with Mach3 makes no problem - Typing in the MDI related gcode like x-140 makes the trouble.
    Thanks for ANY input!
    Video :
    https://youtu.be/zKtvBqYzrs4
    Machine :
    CNC 6040 - watercooled
    1.5 kw
    BSMCE04U-PP Board
    TX14207 Drivers
    If you need anything else, please drop me a line.
    Thank you VERY MUCH
    Aug 2020
    6
    Re: CNC 6040 - X-Axis stutters and Jitters when moving x-, x+ is fine
    Thanks, it is a hardware / driver fault. I switched the 4th (A) axis with the X, since i barely use the A Axis - problem solved.
    Just waiting to get a new exchange.
    But while i am on this and the Drivers are REALLY QUIT GARBAGE :
    Do you know DECENT drivers which can be used in exchange for the TX14207? Do i really need to go for Leadshine? - on the other hand 59Bucks for a Driver shouldnt be the problem - if thats the price
    regArts
    Aug 2020
    6
    Ok,
    i tried simple elements like circles and what i have noticed as well is shown in the video :
    https://youtu.be/cijqWe3Zye4
    At the moment where the direction change occours for the circle, the motor is like jittering or losing steps...
    i have forgotten where i did read how to fix that... it was by adjusting values for the motor tuning.
    This is the "off" for the axis for small circles 15mm and 60mm ... at the end you see the result after the 4th repeat of the same gcode..
    https://youtu.be/LlypKtYVTGg
    thanks and regards
    Sep 2020
    5
    Quote Originally Posted by k0s View Post
    Ok,
    thanks and regards
    Did you even fix that? Im having a similar problem on all my axis . I have the EXACT same machine as yours
    Feb 2015
    11
    To me that sounds like a bearing that is running really ruff in the negative direction. What are they using for bearings?
    Aug 2020
    6
    Angry Re: CNC 6040 - X-Axis stutters and Jitters when moving x-, x+ is fine
    The simple solution was:
    get a new driver i just ordererd new Lichuan drivers, set them up and et voila - sound was more like with pro driver boards (like you hear nothing) movement was smooth and everything was fine.
    i received a replacement driver by the manufacturer but this one was **** as well. so i gone for new ones. the lichuan are around 35€ for me.
    as a side node: the new driver boards fit perfectly in, even the holes are already made in the case xD looks like they shipped a while ago more quality boards with that unit
    enjoy good luck...
    and @jimgeo7 :
    no .. why you think its a bearing? this would lead any other user to a complete wrong direction.. so better keep such guessing for you
    thanks anyways for nothing
  1. Axis stutters when it hits location of tabs
    By dptp9lf in forum Aspire
    Last Post: 11-13-2017, 05:23 AM
  2. axis not moving Only DRO moving on mach3 screen for cnc router 6040
    By bingaom in forum Charter Oak Automation Support Forum
    Last Post: 09-09-2014, 08:54 AM
  3. New 6040 CNC is not moving axis
    By greg_mjak in forum Community Club House
    Last Post: 08-12-2013, 07:29 AM
  4. Z AXIS - Moving bearings or moving rails ?
    By TrickyCNC in forum DIY CNC Router Table Machines
    Last Post: 02-28-2012, 06:22 AM
  5. Suddenly I have Servo Jitters on the Z-axis
    By Deltic_Engine in forum Fanuc
    Last Post: 03-08-2010, 03:25 AM
