587,188 active members*
4,537 visitors online*
Results 1 to 5 of 5
    May 2008
    83
    CNC Build progress Seiber Hegner RB1
    Here is some pics of a bracket i am making for this machine. It will be used to drive the head up and down. I have the machine dial in to cutting within .001". Finally i have a nice reliable machine can't wait to get hte head moving up and down.
    Attached Thumbnails Attached Thumbnails IMG00021-20100401-2203.jpg   IMG00022-20100401-2203.jpg   IMG00023-20100401-2206.jpg   IMG00024-20100401-2206.jpg
    Dec 2014
    3
    Re: CNC Build progress Seiber Hegner RB1
    Hello,
    I acquired a used RB1 Mill recently. The X axis feed screw requires replacement (thread wear - looks like the vise didn't get moved for a long time). Other than having a new feed screw turned, any idea where I might find a replacement?
    Thanks!
    May 2008
    83
    I used a Bridgeport ballscrew assembly for my rb1 build. So any screw for a bridgeport table will work on the rb1
    Dec 2014
    3
    Thanks for the advice.
    The RB1 screw uses a different method of supporting the bearings along with metric keys and handles. I acquired a replacement Bridgeport screw but had to change out the right side bearing support, bearings, and bearing retainer.
    All good as this was still cheaper than having a custom screw machined.
    Any chance you have access to a manual for the RB1?
    I'd be willing to do whatever is needed to get some form of copy if you did.
    Your CNC conversion look like its coming along nicely.
    Thanks in advance...
    46Bobber
    Oct 2005
    278
    I just bought a RB1. Converting it as we speak.
    I do have a copy of the manual. please email me at nate foerg at gmail dot com
    Also, I am converting to ballscrews, so I have screws and mounts avail.
    Nate.
    Ann Arbor Meechigan
  1. LMS SX2 Build progress
    By NewHobby in forum Benchtop Machines
    Last Post: 05-13-2014, 04:19 PM
  2. Seiber Hegner RB1 Milling Machine
    By native34 in forum Bridgeport / Hardinge Mills
    Last Post: 03-08-2014, 04:01 PM
  3. SBR20/MDF build progress
    By frige in forum DIY CNC Router Table Machines
    Last Post: 07-05-2011, 10:15 PM
  4. Build Guide/ Progress
    By bigdrock44 in forum Joes CNC Model 2006
    Last Post: 04-12-2011, 01:10 AM
  5. My first build in progress...
    By ESP Graphics in forum DIY CNC Router Table Machines
    Last Post: 01-04-2010, 11:46 PM
