603,963 active members*
3,212 visitors online*
    Nov 2006
    48
    CNC Conversion Reccomendations
    What 3 axis conversions can you guys recommend for a Bridgeport clone? If I can save some money by doing some work myself that's a plus but I need this to be a accurate and reliable system. I have experience as a electronics tech and a machinist, so I shouldn't have a problem making it work as long as I have some guidance or instructions.
    Dec 2004
    1865
    Hi Greenmachine,
    How much are you willing to spend on the conversion?
    This one question will drive the rest of the conversion.
    Mike
    Warning: DIY CNC may cause extreme hair loss due to you pulling your hair out.
  1. Haas Lathe Reccomendations
    By imwllc in forum Haas Mills
    Last Post: 04-05-2012, 06:21 PM
  2. Lynx 220a or 220c reccomendations
    By joesimmers in forum Daewoo/Doosan
    Last Post: 11-24-2008, 02:41 AM
  3. Upstroke press brakes - Reccomendations?
    By PhoenixMetal in forum Bending, Forging, Extrusion...
    Last Post: 07-27-2008, 09:48 PM
  4. servo conversion vs stepper conversion
    By contractdesign in forum Bridgeport / Hardinge Mills
    Last Post: 07-26-2008, 08:54 PM
  5. Reccomendations
    By milford in forum DIY CNC Router Table Machines
    Last Post: 10-14-2004, 08:57 PM
