603,884 active members*
5,600 visitors online*
IndustryArena Forum > OpenSource CNC Design Center > Arduino > CNC cuts 25% larger than design.
    Mar 2024
    Designed sign in Carbide Create 7 in mm. Grbl Controller sends to CNC Xpro V5 cut is 25% larger than design but true not distorted.
    Apr 2004
    5950
    Re: CNC cuts 25% larger than design.
    Have you measured how far each axis moves when commanded to go a certain distance? The simplest explanation is that your steps per unit need adjustment.
    Andrew Werby
    Website
    Mar 2024
    No I have not. Will start my day off with that tomorrow. Say something about that years back, but neither of my previous machines did such a thing, and I forgot all about it! Thank you!!
  1. Replies: 0
    Last Post: 09-24-2018, 10:41 PM
  2. Replies: 7
    Last Post: 05-23-2017, 09:13 AM
  3. Romaxx CNC WD-2 larger format CNC machine
    By RomaxxCNC in forum News Announcements
    Last Post: 12-18-2016, 08:07 PM
  4. Need someone with a 4'x4' or larger CNC router in Dallas
    By milkit in forum RFQ (Request for Quote)
    Last Post: 01-23-2012, 07:47 PM
  5. which cnc package cuts 2D parts with least extraneous cuts?
    By mbwittig in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-07-2007, 12:29 AM
