603,347 active members*
3,331 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > News Announcements > CNC Cutting Machine for plasma and oxy-fuel
Hybrid View
    May 2007
    11
    Smile CNC Cutting Machine for plasma and oxy-fuel
    Portable CNC Cutting Machine for plasma and oxy-fuel
    We are a Chinese company,located in Beijing,we design,manufacture and
    distribute several type of CNC cutting machine.
    As we are currently looking for representative and distributors in your
    area.
    SteelTailor P is an ideal equipment for the small and medium-scale enterprises, SteelTailor P portable CNC Cutting Machine can be widely applied in industries such as automobile,shipyard,locomotive,petrochemical,aviat ion and aerospace,boiler and pressure vessel,machinery,decoration and large-size metallic signs. The cutting and blanking of metal plates such as carbon steel (flame cutting) and stainless steel,copper,aluminium etc. (plasma cutting) can all be peformed by SteelTailor P. It is a replacement of hand-held flame torch,hand-held plasma cutter, profile and pantographic shape cutting machines.
    SteelTailor P is a portable CNC Cutting Machine.It can cut any complex plane figures as the large-sized gantry CNC cutting machine and support both flame torch and plasma cutter. It is affordable for all enterprises and workshops. The compact design and rational structure make it lightweight,small size and easy to move. It is usable both indoors and outdoors.
    By using high quality controllers in its automation system and antimagnetic materials in its housing, SteelTailor P guarantees a reliable and stable CNC operation.
    The application of the most up-to-date CNC technology allows independent programming from numerical control . equipment failure and maintenance difficulty are reduced.
    The integration of FastCam cutting software makes drawing, nesting and cutting simple and efficient. The software provides high level of material utilization & optimization.
    this is our website about the prodcut,http://www.steeltailor.com
    if you are interested in it,please contact us!
    Msn:[email protected]
    tel:86 010 51290845
    fax:86 010 65705596
    Email:[email protected]
    May 2007
    11
    portable cnc cutting machine
    Portable CNC cutting machine for plasma and oxy-fuel cutting heads Steeltailor
    2-Axis CNC Portable Cutting Machine
    Looking for Dealers, Distributors
    Cut like a big cutting machine with the provided FastCAM software Affordable for all small and medium enterprises Cutting Range: 1200 mm(47")X2000 mm( 78"). Lenght extendable till 6000mm.
    Support both plasma cutter and oxy-fuel cutting torch With its USB port, the data transmission from a PC is as easy as
    downloading photos from a digital camera. SteelTailor has all the performance of a gantry machine.
    An ideal tool for metal work hobbyists, DIY enthusiasts, reparation shops, demolition projects operators, metal scrap yards, street rod chassis builders, machinery works, and others who care about either of the 3 strengths of an oxy-gasoline torch: portability, fuel cost economic, and fuel availability.
  1. CNC oxy/plasma cutting machine form far east
    By satthra in forum News Announcements
    Last Post: 04-26-2007, 10:34 AM
  2. custom plasma cutting machine ?
    By jpcuttergrinder in forum Waterjet General Topics
    Last Post: 11-30-2006, 05:10 AM
  3. I need help about cutting heads which apply to apparel pattern cutting machine
    By sheepgrass in forum Mechanical Calculations/Engineering Design
    Last Post: 05-12-2006, 07:09 PM
  4. Looking for some Plasma Cutting
    By ArcadEd in forum Employment Opportunity
    Last Post: 05-09-2006, 02:26 PM
  5. Plasma cutting mdf.
    By ynneb in forum Waterjet General Topics
    Last Post: 11-06-2004, 02:56 AM
