603,799 active members*
2,561 visitors online*
Page 5 of 7 34567
Results 81 to 100 of 129
  1. #81
    Nov 2015
    67
    Re: CNC egg shell carving
    Steve Jobs
  2. #82
    Nov 2015
    67
    Used a new router bit. The result is a bit better.
    Added a hollow out pattern on the other side also.
    Attachment 351976
  3. #83
    Apr 2003
    540
    I've followed your thread since your first post. I just wanted to say your results are amazing. I imagine there would definitely be a profitable market for selling these. They are honestly works of art. I wish I had a machine and the skills to do these myself. Thanks for sharing.
  4. #84
    Nov 2015
    67
    Thanks a lot Coherent.
    BTW, earned not even a penny.
    All to my friends.
  5. #85
    May 2009
    23
    Quote Originally Posted by uvvvvw View Post
    Attachment 351976
    Is this the opposite side of the Steve Jobs carving? Does it change the light transmission through the carving?
    Sent from my SM-N920V using Tapatalk
  6. #86
    Nov 2015
    67
    yes, it is the opposite side.
    i turned off the LED inside the egg shell while i took the photo of this side.
  7. #87
    Nov 2011
    489
    wonderful! Click image for larger version.
    E-mail: manager@elephant-cnc.com Web: www.elephant-cnc.com
    --------------Jinan Blue Elephant CNC Machinery Co., Ltd-------------
  8. #88
    Oct 2010
    Hi UVVVVW,
    I would love t have a copy of the VB6 program. Is it possible to have it?
    thanks
  9. #89
    Nov 2015
    67
    Sorry Tonino, not prepare to open source at the moment. :cheers:
  10. #90
    Nov 2015
    67
    Lithophanes again
  11. #91
    Oct 2005
    UVVVVW,
    Until I saw your Re: CNC egg shell carving thread, I thought that I was the only one to have built a CNC machine to carve egg shells! Nice to know that I am not alone. I took on the project as a challenge. I didn't really want to carve egg shells, but I did want to build a machine that would.
    I have moved through several design changes over the years. My current machine has 4 axis. Two linear and two rotary. One of the rotary axis is dedicated to keeping the axis of the cutting tool Normal to the surface of the egg. I chose to design the machine with the cutting tool fixed. I thought that would give me more flexability with the tools I could use.
    I attach a spindle for mounting only to the bottom of the egg so that carving can continue to the top.
    Like yours, I use the machine to probe the surface of the mounted egg to get a profile but since (so far) I cut through the shell, I do not require that a point cloud be built. I make one probe pass from the top of the egg to near the bottom and assume symmetry.
    Currently I use a dental air turbine for the carving tool (much like artist that carve by hand) but I find them to be to delicate for hours of constant use. I would be interested in what you have found to be reliable. Yours looks electric which is what I prefer.
    I use AutoCAD with some lisp routines, Vectric's Cut2D, Excel with some macro's for serious number crunching, and Mach3.
    Developing a point cloud to enable relief carving as you have done will be the last frontier for me. I worked on it for a short time but then moved on to something else. With goose egg shells being only 0.011 to 0.015 inches thick, there is not a lot of room for error in relief carving.
    I completed the current machine design several years ago and after an initial flurry of carving, have not done much with it since. I carved a few eggs for friends and family. One friend wanted several dozen for wedding party gifts. OMG! It is not as much fun when you are under the gun to meet a deadline. I gratefully declined.
    Riky Tiky Tavy
  12. #92
    Jun 2010
    4260
    Hi RTT
    There is a way to keep it going. You go commercial - but very high end. You need a polished wood box and with a shaped velvet lining and ...
    Do NOT try to hit the discount end of the market.
    Cheers
    Roger
  13. #93
    Nov 2015
    67
    Quote Originally Posted by Riky Tiky Tavy View Post
    UVVVVW,
    Riky Tiky Tavy
    Hi Riky,
    I am glad that I'm not alone also
    Mine is a simple 3 axis machine.
    Dental air turbine is good.
    I saw quite some people use it to carve egg shell by hand.
    But I don't want to use it, as it is quite noise.
    And air compressor is required.
    I am using a blushless DC spindle for the carving.
    70K rpm, not as high speed as the dental air turbine.
    But much more silent.
    Of course, cannot cut the egg shell as fast as the dental one.
    I use Inkscape and Photoshop for the graphic design.
    And use the Inscape laser plug in and Artcam for the Gcode generation.
    I wrote my own program for the post processing.
    I have not much pressure. Just some gifts for friends.
    BTW, people like the lithophanes
  14. #94
    Oct 2005
    Hi UVVVVW,
    Your CNC lithophanes have given me a renewed interest in carving. I believe I will dust off my machine and start experimenting again.
    I have ordered a more durable (I hope) dental turbine with ceramic bearings. I have a new idea on mounting/holding the turbine that I believe will make the turbine more reliable. Noise is not a problem because the carving is done in an enclosure.
    I have done a poor job of documenting my processes form start to finish and if I'm away for several months to a year, I have to retrain myself.
    Riky
  15. #95
    Nov 2015
    67
    Internal engraving.
    First trial to engrave an image inside an egg shell
  16. #96
    Jun 2010
    4260
    On the inside???
    OK, that's new.
    LONG shank with ball end and come up through hole in bottom of egg? Still with only 3 axes?
    Or large egg and right-angle dental drill?
    Cheers
    Roger
  17. #97
    Nov 2015
    67
    Hi Roger, good to see you through the internet again
    On the inside???
    (yes)
    (normal 0.2mm flat tip 30 degree engraving bit. not really long shank one. not a hole in the bottom, but a big hole in the back. you can see it in the 3rd pic)
    (yes, same machine)
    (normal 90mm long goose egg. not right-angle one, just normal spindle. i use a brushless DC spindle)
    CK
  18. #98
    Jun 2010
    4260
    Ah - I see. Very clever too.
    Cheers
    Roger
  19. #99
    Nov 2015
    67
  20. #100
    Nov 2015
    67
    My first gourd
Page 5 of 7 34567
  1. DIY Laser Shell
    By trotec in forum Australia, New Zealand Club House
    Last Post: 11-30-2013, 07:06 AM
  2. Shell Moulding
    By razajahanian in forum MetalWork Discussion
    Last Post: 11-09-2010, 11:55 AM
  3. Using a shell mill
    By mrk in forum MetalWork Discussion
    Last Post: 08-11-2007, 02:59 PM
  4. Relief carving small detailed parts - V-carving from greyscale image
    By ALAN2525 in forum Uncategorised CAM Discussion
    Last Post: 02-12-2007, 12:01 AM
  5. Cutting Shell
    By handersen in forum Glass, Plastic and Stone
    Last Post: 07-09-2003, 01:04 PM
