I see but what happens if a stepper misses a step...? itruely dont know which is the better option in the end?
so the gantry going out of tune isnt a problem you say,,,i really am great full for your help i will have to think alot about it !
I know the decision process at the beginning of a project can sometimes be overwhelming, however at the end of the day the decision is yours as to the construction method.
You simply have to consider the information that is available, make an executive decision and move forward.
So i have made a choice to buy one more motor .....the timing belt choise is much much more time consuming to built....so now the facts are that
1)i will use slave motor with one more driver and also one more power supply
2)the gantry is going to run with two ballscrews one one axis
3)the motors are going to be connected with the ballscrews with timing belts?(on this one i need some advice please) or i should make some oldham couplers ( not the easiest thing in the world and not available in my country or on ebay)
So i am thinking also not to put the second bearings on the left side of the gantry cause i think it doesnt need it ? please tell me your opinions on that too ?![]()
i have some reasons...first i want to keep the containing box..(but on the other hand i can modified it layter on) i am afraid of the misalignment on the motor with the leadscrew that will cause the motor to wobble. Another plus to this setup is that you can layter change the analogy with the timing pulleys...or then i should make some oldham couplers but not the easiest thing to do...
