603,975 active members*
3,342 visitors online*
Results 1 to 15 of 15
    Jan 2007
    161
    cnc lathe canned cycle issues
    Hello,
    Sorry I posted the original in the wrong forum
    I am having troubles... I have been CNC turning parts for years. I buy a used small CNC lathe, 1998 Femco with a Fanuc O-T control. I score a small first job. Now I try and run the machine for the first time and it doesn't like the canned cycles.
    Please help... Could it be the a turned off parameter??
    The alarm reads 010 P/S. My books says "unusable G code commanded" It bombs out when it reads the G71 line and the G76 line. I can work around the G71 rough cycle but I need to be able to thread the part.
    Here is the code
    (ROUGH OD PROFILE)
    G00X1.Z.03
    G71U.1R.015
    **G71P1000Q1001U.01W.005F.007
    N1000G00X.6794
    G01Z-.0059F.02
    X.784Z-.044
    Z-.465
    X.8072
    G03X.8892Z-.506R.041
    G01Z-.975
    X.938
    N1001X1.
    G0Z1.
    and the threading cycle too
    (FINISH THREAD)
    T0303
    G97S1000M03
    G00G99X1.Z.25M08
    G0X.984Z.2
    G76P011060Q0010R0010
    **G76X.744Z-.4095R0P0200Q0047F.059
    G00X.968Z.2577
    G0Z1.
    I am drowning.. please help
    __________________
    _____________
    teamjnz
    Jun 2005
    232
    Just a shot in the dark whats the g99 on the lathe used for, could the alarm be because of the g99. The g99 is return to R level for fixed caned cycle . I have never seen a lathe that uses g99. Take out the g99 and see what happens reboot the machine sence g99 is modal.
    The R in the g76 code needs a . point
    Tim
    Jan 2007
    161
    Thanks for the input Tim.
    G99 for the lathe is feed per revolution and G98 is feed inches per minute. These codes are different for the mill in the canned drilling cycles.
    I was able to produce a G92 thread cycle. I am confused why this the G92 cycle works and the G76 does not. The thread relief is small and the G92 starts retracting to soon and doesn't give me full thread before the shoulder.
    Any other input would be nice.
    _____________
    teamjnz
    Nov 2006
    174
    G71/76
    I don't do turning but I seem to recall reading somewhere that older controls use just a single line input for G71/76.
    Don't know the format for the block info but try a "search" for G71 single line input.
    Nov 2006
    174
    Done a search
    O1000(Program number)
    N1 G50 S2500(Max speed)
    N2 T0101
    N3G96 S600 M3(Speed in SFM for 1018 Steel)
    N4 G0 X4.0 Z.1 M8(Rapid to OD of part, .1" away from face, turn coolant on)
    N5 G71 U.15 R.02(U=cutting depth, R= pullaway distance after each cut)
    N6 G71 P7 Q9 U.05 W.005 F.015(P7 tells the control to look at N7 and Q9 to look at N9, this is how we give the motions describing the part.
    U is the amount of stock left for finishing on the OD, W is the amount left on the shoulder.
    N7 G0 X2.0
    N8 G1 Z-1.0
    N9 X4.0
    N10 G0 X6.0 Z6.0 M9(Rapid back to a position clear of the part, turn coolant off)
    N11 M30( End of program)
    Notes: The 6T version has a single line and so do various Yasnac controls, they look like this:
    N5 G71 P7 Q9 U.05 W.005 D1500 F.015(D= depth of each pass and has to be given as a value
    without a decimal point)
    This cycle is normally followed by G70( Finish Cycle) after tool change to a finish tool. Rapid to the
    same position for the start of the G71, then program G70 P7 Q9.
    Mar 2003
    2932
    Whether your control uses 1-line or 2-lin multiple repetitive cycles depends on parameter TAPEF (see attached).
    1=F10/F11 Format (1-line)
    2=F0 Format (2-line)
    Feb 2010
    5
    I've had this happen. The canned cycles need to be switched on by someone who knows where to look (I had a service engineer with me who had good contacts)
    Feb 2006
    992
    Angry
    Quote Originally Posted by teamjnz View Post
    Since "unusable G code" alarm, I have a feel the machine don't has option G71 to G76. Long hand program is only choice.
    The best way to learn is trial error.
    Jan 2005
    150
    Hello,
    Here is the code
    (ROUGH OD PROFILE)
    G00 X1. Z.03
    G71 P1000 Q1001 U.01 W.005 D0.03 F.007
    N1000 G00 X.6794
    G01 Z-.0059 F.02
    X.784 Z-.044
    Z-.465
    X.8072
    G03 X.8892 Z-.506 R.041
    G01 Z-.975
    X.938
    N1001 X1.
    G0 Z1.
    (FINISH THREAD)
    T0303
    G97S1000M03
    G00G99X1.Z.25M08
    G0X.984Z.2
    G00X.968Z.2577
    G0Z1.
    __________________
    Try single line G71 canned cycle.
    What kind of material are you cutting? And the OD tolerance? If its a critical part dimensionally speaking (tenths), I'd run at least two or more passes across the OD, cutting the same amount on each pass. This can be done when you call up the G70 and set your 'U' and 'W' values accordingly.
    Example with 3 passes with the G71 U0.009 and W0.003:
    G70 P1000 Q1001 U0.006 W0.002 F0.004
    G70 P1000 Q1001 U0.003 W0.001
    G70 P1000 Q1001 (final dimension, no need to use U or W)
    I'll assume that you already know this bit of knowledge but I'll state it anyway for those who are reading this post and may not know... You can put several G70 lines below each other and the machine will not alarm out. This is because it will start at the G71 lap starting point (X1.0 Z0.03) when it reads each G70 line. Hence, no crash.
    Now to the threading...
    M24 (THREAD TAPER OUT OFF)
    (M23 = THREAD TAPER OUT ON)
    G76 X0.744 Z-0.4095 K0.000 D0.002 F0.059
    (K = MAJOR DIA MINUS MIN DIA / 2)
    (D = THREAD DEPTHS OF CUT)
    (FEEDRATE = 1 / # OF THREADS)
    Hope this helps you out. Let me know how it goes for you.
    Patrick
    Feb 2010
    Quote Originally Posted by SanDiegoCNC View Post
    Patrick
    jamie0579, simply switch off the tool nose radius compensation command after stock removal G40, then use G33 thread cutting command.Hope this was useful.
    Feb 2010
    simply switch off your tool nose radius command ( G40 ), then use G33 thread cutting. G76 is a tapping code not threading you must use G33.Let me know if this was any help as i have encountered this myself,and redited the programme with G33.
    Feb 2010
    You have too switsh off your tool nose radius compensation command, which is G40 and but also acctivate it at the beginning of your roughing cycle, which is G41, as for the treading cycle try using G33 thread cuttting this is a more stable thread cutting command as G76 is commonly used as a tapping command,please let me know if this was useful.
    Jan 2005
    150
    Quote Originally Posted by jamie0579 View Post
    ??Huh??
    Jan 2005
    150
    I'm sure you realize that, depending on the machine, G codes do vary. For instance, a G71 on most machines is a lap turning cycle. But on an Okuma, it is a threading cycle. Teamjnz's code used the G76 for threading. I used a different posting style of the same G76 code because he is using an older model lathe (1999). Please also notice the following...
    On a tapping cycle, I wouldn't call out a 'K' or 'D' value and I sure wouldn't start tapping in 'X0.744'.
    Thanks.
    Jan 2005
    150
    Here's a real example program that has several different lap cycles going on in it. I wrote this program for a Haas SL10 (Model year 2005).
    O00066 (DWG# TX-10309 REV. NA)
    (1 OP)
    (9/16 HEX HOUSING)
    (MATERIAL: 9/16 HEX)
    (CURRENT PROGRAM DATE: 7 FEB 2007)
    (ORIGINAL PRG DATE: 7 FEB 2007)
    (CYCLE TIME= 0 M 0 S)
    (TOOLS LIST)
    (TOOL 1 CNGP431 0.0156 RADIUS ROUGH TURN)
    (TOOL 4 OD THREADING TOOL)
    (TOOL 5 CNGP 43.0 RADIUS 0.007 FINISH TURN)
    (TOOL 9 SPOT DRILL)
    (TOOL 6 F DRILL 0.255 DIAMETER)
    (TOOL 11 0.120 WIDE CUTOFF BLADE)
    (TOOL 3 PART STOP)
    G20
    (EXTEND STOCK 2.210)
    (TOOL - 1 OFFSET - 1)
    G28 U0. W0. M05
    G00 T101 (CNMG-431 0.0156 RADIUS)
    G97 S1600 M03
    G00 G54 X0.75 Z0.2
    G50 S1600
    G99 G00 X0.75 Z0.1
    M08
    G01 X0.75 Z0.1 F0.02
    G71 P30 Q40 U0.004 W0.002 D0.02 F0.004
    N30 G00 X-0.04
    G01 X-0.04 Z0. F0.003
    G01 X0.378 Z0.
    G01 X0.438 Z-0.03 (CHAMFER ON THREAD FACE)
    G01 X0.54 Z-0.6
    G01 X0.75 Z-0.705 (CHAMFER ON HEX)
    N40 G01 X0.75
    G00 X0.75 Z0.05 M09
    G28 U0. W0. M05
    T100
    M01
    G28 U0. W0. M05
    G00 T404 (OD THREAD TOOL)
    (1/4 NPT X 0.6 OAL)
    (CHECK THREAD AFTER FINISH TOOL)
    G97 S800 M03
    G00 G54 X0.54 Z0.2
    G50 S800
    G99 G00 X0.54 Z0.15
    M08
    G01 X0.54 Z0.1 F0.03
    G92 X0.54 Z-0.55 I0.034 F0.0555 M24
    (G92 IS MODAL THREAD CYCLE)
    (X0.54 IS FIRST THREAD DIAMETER)
    (Z IS THE THREAD LENGTH)
    (I IS THE TAPER AMOUNT OVER THE LENGTH OF THREAD)
    (F IS THE FEEDRATE)
    (EACH OF THE FOLLOWING LINES IS ANOTHER DEPTH OF CUT)
    X0.525
    X0.53
    X0.525
    X0.52
    X0.515
    X0.51
    X0.505
    X0.5
    X0.495
    X0.49
    X0.485
    X0.48
    X0.475
    X0.47
    X0.465
    X0.46
    X0.455
    X0.45
    X0.445
    X0.44
    X0.435 (FINAL THREAD DEPTH)
    X0.435 (SPRING PASS ON FINAL THREAD)
    G00 X0.54 Z1.
    M09
    G28 U0. W0. M05
    T400
    M01
    G28 U0. W0. M05
    G00 T505 (FINISH PASS 0.007 RADIUS)
    G97 S1600 M03
    G00 G54 X0.75 Z0.1
    G50 S1600
    G01 X0.75 Z0.05
    M08
    G70 P30 Q40 F0.004
    M09
    G00 X2. Z1. M09
    G28 U0. W0. M05
    T500
    M00 (CHECK THREAD)
    G28 U0. W0. M05
    G00 T0909 (SPOT DRILL)
    (NO COOLANT NEEDED)
    G97 S1000 M03
    G00 G54 X0. Z0.1
    G50 S1000
    G01 X0. Z-0.02 F.005
    G00 X0. Z0.1
    G00 X2. Z1.
    G28 U0. W0. M05
    T900
    M01
    G28 U0. W0. M05
    G00 T0606 (F DRILL 0.255 DIAMETER)
    G97 S800 M03
    G00 G54 X0. Z0.1
    G50 S800
    M08
    (G83 Peck Drill using I,J,K)
    (I=Amount of First Peck Depth)
    (J=Reduced Peck Depth Amount)
    (K=Minimum Peck Depth Amount)
    G83 X0. Z-1.5 I0.05 J0.05 K0.1 R0.1 F0.003
    G00 X0. Z0.1
    G00 X2. Z1. M09
    G28 U0. W0. M05
    T600
    M01
    G28 U0. W0. M05
    T1111 (0.120 WIDE GROOVE/CUTOFF)
    (TOUCH OFF ON LEADING EDGE)
    (PROGRAM ADJUSTS FOR OAL)
    (AN EXTRA 0.005 IS LEFT FOR 2ND OP)
    G97 S900 M03
    G00 G54 X0.75 Z1.
    G50 S900
    G01 X0.75 Z-1.47 F0.1
    M08
    G75 X0.52 I0.015 F0.001 (PECK ROUGH CUTOFF CYCLE)
    G01 X0.75 Z-1.47 F0.04
    G01 X0.75 Z-1.365
    G01 X0.6 Z-1.47 F0.001 (REAR CHAMFER ON HEX)
    G75 X0. I0.015 F0.001 (PECK FINAL CUTOFF CYCLE)
    M09
    G00 X2. Z1.
    G28 U0. W0. M05
    T1100
    M01
    G28 U0. W0. M05
    G00 T0303 (STOCK STOP)
    G00 G54 X1. Z0.1
    G00 X0. Z0.06
    M05
    M00 (PULL STOCK)
    G00 Z1.
    G00 X2.
    G28 U0. W0. M05
    T300
    M99
    M30
  1. canned cycle for lathe with fanuc control
    By JPann in forum G-Code Programing
    Last Post: 09-27-2011, 06:45 PM
  2. Canned OD cycle?
    By VWbmx in forum Haas Mills
    Last Post: 06-05-2009, 06:17 PM
  3. G76 Canned cycle
    By Stebedeff in forum Fanuc
    Last Post: 02-07-2008, 06:42 PM
  4. Lathe drilling canned cycle
    By cijunet in forum GibbsCAM
    Last Post: 12-08-2007, 11:38 PM
  5. Canned cycle output in Gibbs lathe
    By naytep in forum GibbsCAM
    Last Post: 08-30-2007, 08:38 PM
