603,935 active members*
5,897 visitors online*
Results 1 to 5 of 5
    Feb 2007
    972
    CNC Lathe chuck with adjustable Jaws ?
    On my Samsung PL10 cnc lathe (just got it), How do I true the chuck after moving the jaws on their cerated mounting. They are off by about 0.005"
    These are hardened jaws and i don't want to have to grind them true.
    This must be a common thing since they need to be moved for each size of part.
    Nov 2006
    925
    You don`t use hardened jaws for jobs where you are not machining the bar dia,only use them for jobs where you are machining all over and parting off or for first ops on forgings/castings.For everything else use soft jaws and true them after setting.
    Mark.
    Feb 2007
    972
    Thanks, thats what i needed to know.
    The chuck is a Sanchully HAS-08, ever heard of it ?
    Jul 2005
    12177
    Quote Originally Posted by Larken View Post
    On my Samsung PL10 cnc lathe (just got it), How do I true the chuck after moving the jaws on their cerated mounting. They are off by about 0.005".....
    gridley51's comment is correct but your hard jaws should be better than .005" off. Are they numbered and in the correct location? If they are not numbered label them so you know which is which, and then move them around so you have tried all combinations of the jaws in different locations. You might find one thet runs truer so then you mark them permanently to stick with that position.
    Oh, of course, the simple check...make sure the serrations are clean.
    May 2007
    1003
    Quote Originally Posted by Geof View Post
    gridley51's comment is correct but your hard jaws should be better than .005" off. Are they numbered and in the correct location? If they are not numbered label them so you know which is which, and then move them around so you have tried all combinations of the jaws in different locations. You might find one that runs truer so then you mark them permanently to stick with that position.
    Geof is correct. Relocating the jaws can change concentricity by quite a bit.
  1. Boring soft chuck jaws for ID holding?
    By SRT Mike in forum MetalWork Discussion
    Last Post: 03-15-2013, 07:19 PM
  2. How to - cutting lathe soft jaws?
    Last Post: 07-26-2010, 12:47 PM
  3. Which lathe chuck?
    By CNC Pro in forum MetalWork Discussion
    Last Post: 08-25-2008, 02:57 PM
  4. Macro for Boring lathe Jaws - Fanuc 21i-T
    By CNCSport in forum Uncategorised MetalWorking Machines
    Last Post: 10-17-2007, 11:07 PM
  5. truing lathe chuck jaws
    By wrenchcruncher in forum Uncategorised MetalWorking Machines
    Last Post: 01-17-2007, 07:03 PM
