603,385 active members*
3,947 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Controller & Computer Solutions > CNC Lathe controlled with OLD! PC, can I change the PC and SOFTWARE??
Page 2 of 2 12
Results 21 to 35 of 35
  1. #21
    Sep 2014
    51
    Re: CNC Lathe controlled with OLD! PC, can I change the PC and SOFTWARE??
    sounds doable think I'll just change the steppers and drives then
    could you maybe send me some links for the stuff I'll need?
    greatly appreciate your inputs!
    ps. for the C-axis I'll attach an auxilary servo on the final spindle but let's not worry about that for now
    I have very little experience with mach3 by now so it wouldn't be much of a step back to get started with another software (i.e. linuxcnc) so I guess I'll just follow your advice all the way
    -linuxcnc basically has the same programming capabilities as Mach3 right?
  2. #22
    Oct 2010
    1189
    If you like you can use my Build log of my lathe but it is on The Old Homepage but ill Switch it on for you the Transfer is manually. So it is Not on the New so far ,..
    Gesendet von iPad mit Tapatalk
  3. #23
    Sep 2014
    51
    That would be very nice thank you!
  4. #24
    Oct 2010
    1189
    hi yesterday i have transferred the relevant parts to my new portal (wish i had a script )
    Klippfeld K10B Drehbank Factory retrofit - tkamsker
    it is german because i had no time to translate but goolge translate will help and pictures say more than 1000 words as we say in german -
    thomas
  5. #25
    Sep 2014
    51
    thank you very much! I'm looking in to it (my german's really bad so it might take a little while :b)
  6. #26
    Sep 2014
    51
    So I need to buy the triple beast controller - and 3 pcs. stepper motors
    does stepper and limit switches just connect to the triple beast then?
    do I connect the triple beast to the computer or is there something in between? (and can it be connected just using USB)
    Might be easier to understand when I've bought the stuff...
  7. #27
    Oct 2010
    1189
    Hi Triple Beast is just one of the options (leadshine g540 would be another) and Yes you can connect endswitches Vfd to it 2 Relais are also in there i have choosen them because of silence Ampere and really build in germany i know there is an USB possibilty but i use lpt board and linuxcnc so Yes you need an PC i have one with an it x board and lpt on them
    Benezan Electronics
  8. #28
    Sep 2014
    51
    the G540 seems a lot cheaper.. any reason why i shouldn't choose that?
  9. #29
    Oct 2010
    1189
    Hi it depends
    I have chosen the triple beast because my steppers exceeded 3A i have one 4.6 A Stepper thats why i choose trp but looking at the manuals
    http://www.benezan-electronics.de/ma...BOB-Manual.pdf and http://www.geckodrive.com/images/cms...8%20Manual.pdf
    there are differences depending if it suits you.
    i am under the impression that at gecko you need an 2nd 12V power supply
    if you have smaller (3A ) Steppers then it might be sufficient
    the trp also have some kind of sinus following (just read it in the spec) and thats why they are extreme silent. And strong. (i compared them to an breakout board and Leadshine 5xx
    but really i think it doesn't matter read the specs see why suits you and go for it
    thomas
  10. #30
    Sep 2014
    51
    ok. thanks a lot!
  11. #31
    Sep 2014
    51
    What about Leadshine MX3660, does anyone know that? that looks like a simple solution? couldn't I use that? (I like the "plug 'n Play type :b )
  12. #32
    Oct 2010
    1189
    Hi yes from paper form it Looks Good the mx3660 but i have no experience with it what dös it cost ?
  13. #33
    Sep 2014
    51
    found it on ebay or about 270 USD... so seems like the same price range as similar products..
  14. #34
    Oct 2010
    1189
    I now help a Factory to Build similar as you if they get the Order i ll do the Control stuff so if you like i post it here or in an own thread up to you ,..
  15. #35
    Sep 2014
    51
    Sounds great. Any news on that yet?
Page 2 of 2 12
  1. Find Software for Z zero after tool change
    By Mr.Chips in forum Calibration / Measurement
    Last Post: 01-12-2012, 03:31 AM
  2. Replies: 0
    Last Post: 06-11-2010, 07:59 AM
  3. I want to change my software ?
    By eng_semsem1980 in forum Screen Layouts, Post Processors & Misc
    Last Post: 07-10-2007, 06:36 AM
  4. cnc controlled mandrel bender controlled by mach3
    By timmyb199 in forum Bending, Forging, Extrusion...
    Last Post: 05-31-2007, 12:35 AM
  5. Software change request
    By widgitmaster in forum Mach Software (ArtSoft software)
    Last Post: 11-26-2005, 03:38 AM
