603,896 active members*
4,508 visitors online*
    Mar 2007
    215
    Question CNC Lathe Problem - Program Freezes up
    Hello guys, I am fairly new to this line of work, about a year of experience. I am having a problem with my Wasino LJ-103m Lathe. I have a sub-program that I have automated and about every 5 parts my machine will freeze on a specific tool. Usually I can enter jog mode and travel the tool around returning it to its previous position, hit start and everything is fine for another 5 parts. Any thoughts on this?
    Jan 2007
    355
    I'm not familiar with this lathe, and I may be totally off base, but here goes...
    It sounds like a stack overflow.
    Make sure that you are returning from the sub before calling it again.
    It may be that your subroutines and/or local variables are nested too deep.
    Post the program code and someone will undoubtably figure it out.
    Mar 2007
    215
    Thanks for the reply Eurisko, I will definitely post that program.
  1. Mastercam Lathe V9 Problem
    By jjwl89 in forum Mastercam
    Last Post: 03-23-2007, 08:54 AM
  2. Difficult Lathe Fixture Problem
    By seco in forum Uncategorised MetalWorking Machines
    Last Post: 09-22-2006, 05:02 PM
  3. Sl20 Lathe Problem
    By MR D in forum Haas Mills
    Last Post: 08-22-2006, 09:38 PM
  4. Bridgeport EZ-PATH 1S Lathe problem
    By Rich Meredith in forum DNC Problems and Solutions
    Last Post: 07-27-2006, 07:39 PM
  5. Problem cutting arc with lathe.
    By mudwhump in forum G-Code Programing
    Last Post: 05-23-2004, 06:19 PM
