603,954 active members*
3,301 visitors online*
    Jan 2013
    15
    CNC lathe: Run-out problem
    Check this video first:
    1 Pictures, 1 Images, 1 Photos, 1 Videos - Video - TinyPic - Free Image Hosting, Photo Sharing & Video Hosting
    And then this:
    2 Pictures, 2 Images, 2 Photos, 2 Videos - Video - TinyPic - Free Image Hosting, Photo Sharing & Video Hosting
    Why material in collet run out ? Where is the problem ?
    Bad collet ?
    Please give me any advice for that.
    Jan 2013
    15
    Re: CNC lathe: Run-out problem
    Is it a problem because of too small collet presure ?
    Edit:
    Im searching forum for some info and i found this:
    300 - 500 psi sounds about right,
    Remember those times when would use lot less on thin walled bored parts
    and of course never, never , close a collet without part in it at 300 psi,
    been there done that , wrote the check for new one,
    Good luck,
    I did that (text in bold).
    can anyone else confirm this ?
    I have this collets: DIN 6364 163 E
  1. V25 lathe Problem
    By kawman in forum BobCad-Cam
    Last Post: 07-18-2013, 10:00 PM
  2. Lathe problem
    By Pressco in forum Mastercam
    Last Post: 08-11-2011, 08:36 PM
  3. new lathe problem
    By tjd10684 in forum Uncategorised MetalWorking Machines
    Last Post: 06-15-2011, 04:21 PM
  4. Backlash Problem on a Lathe
    By Cartierusm in forum Benchtop Machines
    Last Post: 05-30-2009, 02:25 AM
