You're a champ! I like your retaining ring plan better than the others too now - the picture was what I had envisaged from your description but somehow seeing it made it clear. That should work well. It also helped me come up with a way to retain the bearings from the inside while still using the same size bearings at both ends of the spindle, so I can use the bearings I have, QDB and DB as we talked about. I will do a drawing and get you to take a look.
I went and found my bearing specs ok, but I couldn't find how much to derate it by as a quad set - the specified speed for (I assume) 1 bearing was 16,000 rpm with grease... I think you're right - I should be ok at 3000 rpm. I'd like a bit more headroom, but don't actually know what I'll need, so I'll shoot for perhaps a bit higher and watch the temp. I was intending to use a T5 belt and aluminium pulleys - would that be an option for you, to get your revs a bit higher (if you need higher, that is...)?
About the Inpro seals - thank you, I hadn't really considered that I could use bigger than the bearing size. Doh. Should be no trouble to get some affordably!
Glad to hear your ballscrew spec - that's similar to what I wanted to use. I have been playing with a crazy idea to use a big 40 mm dia x 12 mm pitch C3 ground NSK I bought by mistake and use it to add rigidity to a big single rail setup. No doubt I'll get laughed off the site for that
Best regards,
Jason
I forgot to ask - what would you say is a reasonable wall thickness for the spindle wall? I could keep it around 9 - 10 mm easily enough now, and still get a 40 mm + bore...
