587,997 active members*
2,615 visitors online*
Results 1 to 12 of 12
    Oct 2010
    CNC machining in London UK?
    I am looking to have some small and precise parts made.
    Brass disks that are 2.75 mm wide and 0.38 mm thick amongst other parts.
    Ideally I would like to find a hobbyist in London or near London...I am not against paying for the parts, but I would like to learn some more about machining and don't think I would just sending the work to a large company.
    Any suggestions appreciated!
    Thanks!
    Apr 2007
    151
    The best method to get such small disc's made it to punch them out of sheet brass of the desired thickness, how many disc's do you need?
    Regards
    Mike
    Oct 2010
    Hi Mike,
    Thanks for the reply.
    I also need some small flat bottomed pockets made in the disk. (see below)
    I have had the disks made via stamping before but the quality wasn't very good.
    Sep 2007
    359
    You are gonna struggle to get that copper part made with those diameters.
    Curious why you want a london shop, are you after looking while the jobs being run ?
    Phil
    Sent from my HTC Desire using Tapatalk
    Oct 2010
    Hi, I 'm really just looking for a hobbyist in a shed!
    I have been reading up on buying my own taig mill and trying it all out for myself...
    I am not sure if that is the best way to go or just to get some one else to make the parts.
    I have tried to get a Chinese company to make the parts but they were not very good/precise.
    So in short I am looking for some one who is already set up to make the parts or to point me in the right direction.
    I can read all the posts and watch all the videos but actually meeting some one with a lathe/mill set up who has 30 minutes for a chat over a coffee or pint would be a lot more help =)
    Jul 2009
    317
    If U are in California; I can Help U.
    [email protected]
    Sep 2007
    359
    Quote Originally Posted by reddragon View Post
    Hi, I am a toolmaker working in a shed with better than average machines, what I am saying is that I would struggle to make those parts.
    Copper is a very difficult material to work with.
    So I can say with all certainty that you would fail to make them.
    Phil
    Oct 2010
    Hi Phil,
    I had read that a Taig lathe would be able to make the part?
    How would this part be made otherwise?..A more accurate lathe?
    Sep 2007
    359
    The problem as I say is the small diameters. A company that makes watch parts would be a good place to start looking for.
    You would need a high speed spindle definitely and diamond tools probably.
    I believe these machines are called swiss lathes.
    Taig forget it
    Phil
    Oct 2010
    Hey up all, my first post on this site though I've been visiting for some time, noticed this discussion, and I think (and maybe the other contributers would agree) that you might get further with your mission to make your thing if you gave a bit more info. The drawing you posted is confusing in relation to the discs you want to make. But presumably they fit in the middle (?), do they become part of the whole? I don't quite understand, but it might be if you describe the end part that you're after, that you'll find the solution. You might be able to make it in one piece instead for instance on a fine CNC lathe, ???
    Nick
    Nov 2007
    1702
    Quote Originally Posted by M250cnc View Post
    Taig forget it
    Listen to this man. He's trying to help as well as educate you.
    Greg
    Mar 2011
    One half of a millimeter..... thats really really small! Grab your tools and measure that....watch maker stuff is the way to go. The whole part would fit under your finger nail and you'd never know its there!
  1. Hello from London
    By yngvai in forum European Club House
    Last Post: 04-08-2010, 09:34 AM
  2. Help needed in UK (London)
    By littlefraggle in forum United Kingdom
    Last Post: 10-27-2009, 06:54 PM
  3. Hi from London
    By bugdog in forum United Kingdom
    Last Post: 09-17-2009, 07:54 AM
  4. Hi from London
    By Ed_ in forum United Kingdom
    Last Post: 09-30-2008, 10:10 PM
  5. Anyone near London?
    By zoeper in forum Bridgeport / Hardinge Mills
    Last Post: 08-05-2006, 10:40 PM
