603,936 active members*
3,762 visitors online*
Results 1 to 4 of 4
    Feb 2009
    7
    CNC machinist / programmer position - CT
    We are looking for a CNC machinist / programmer for our job shop. We have expanded our milling capacity and need extra help in the area of programming, setting up, and running 3-5 axis VMC's. Currently using mastercam 9 but most likely going to X this year. This position also requires that you be proficient with 3D cad software (preferably Pro/E) as many of the jobs you would be working on are model only (no 2d drawings provided by customer). Please contact me if interested, but please only if you actually have the ability to take a drawing or model through to finished product with little or no assistance. Shop is located in Newington, CT.
    We are not interested in contract programming. We need someone in house to physically set up machines and run parts on top of programming... The typical milling projects are of low quantities and require new programming and setups 1-3 times/week
    Dec 2008
    Quote Originally Posted by alliedm View Post
    hai
    i am mani, indian. now i am working in nigeria
    Apr 2005
    3634
    Howdy ?
    Free DXF - vectorink.com
    Nov 2008
    Apply
    Dear Mr/Mrs/Ms,
    I would like to apply for the job.
    I have Mechanical Engineer Bachelors degree(2004) . I have 3 years experience with CNC machines, specially with mill machines, but I have no problems with lathes. I know G-codes, and Hedenhain codes too. I can work alone. I can work with CAM softwares, and also with SolidEdge and AutoCAD.
    I think I work hard, I can find out solution for problems. I worked in the USA as a CNC operator 1th and 2th shift, so work time can be in any shift.
    Nowdays I work as a designer and a cnc programmer. I worked with metals(stainless steel, aluminium(with ERGAL too), plastics, graphit etc.). I Have experience with 3axes and 4axes mill machines (G-codes, Heidenhain).
    I would like to strart to work as soon as possible. I'm living and working now in Hungary, but ready to leave right now.
    Thank you for your time!
    Best Regadrs,
    Laszlo Simon
    [email protected]
    +36 20-264 7988
  1. CNC Machinist/Programmer - Connecticut
    By lbi17 in forum Employment Opportunity
    Last Post: 02-08-2009, 08:57 PM
  2. CNC MACHINIST / PROGRAMMER
    By J.BREWER in forum Employment Opportunity
    Last Post: 08-20-2008, 01:49 PM
  3. machinist/programmer
    By 1METALHEAD in forum Daewoo/Doosan
    Last Post: 03-06-2008, 08:46 PM
  4. CNC Programmer/Machinist
    By schiada96 in forum Employment Opportunity
    Last Post: 10-03-2007, 01:36 PM
  5. Programmer Position
    By JIMMY in forum Employment Opportunity
    Last Post: 11-13-2006, 10:33 PM
