587,338 active members*
3,631 visitors online*
Results 1 to 1 of 1
    Jan 2010
    125
    CNC Master and Slave problem
    We have a cnc router with an A and X drive slaved together and controlled by a usbcnc controller called usbcnc cpu5
    Eding CNC - PC based CNC control. When I enable the drives in the software the drives move slightly and put the machine out of alignment which I can fix by jogging at high speed. The control board maker insists it's machine tension within the cnc but it moves freely with no power. I am using leadshine drivers to control the two steppers which are 6 newtons. Wondering if anyone has any tips to fix this? Maybe change the dip switch settings on the steppers? Anytime we turn it off and on it needs to be realigned and makes an awful noise until we high speed jog it. Thanks
  1. Problem with X and A slave axis
    By deemon328 in forum Uncategorised WoodWorking Machines
    Last Post: 09-02-2010, 07:00 PM
  2. Master and Slave axes in EMC2+Montec
    By Andrey_Ld in forum LinuxCNC (formerly EMC2)
    Last Post: 07-03-2010, 08:56 PM
  3. Master Slave Trolley Arangements?
    By technomage in forum Linear and Rotary Motion
    Last Post: 05-23-2007, 10:36 PM
  4. master-slave servos
    By js412000 in forum Servo Motors / Drives
    Last Post: 03-09-2007, 07:36 AM
  5. Master and Slave servo
    By Builder in forum Servo Motors / Drives
    Last Post: 11-02-2004, 03:55 PM
