Originally Posted by
SBC Cycle
That's pretty slick Toby
I made this at home because the shop I was working at was using a lot of CBN Miniature End Mills from Harvey Tool. They cost $221.00 for a .6mm to $235.00 for a 2mm. The other guys were chipping the tools on touch off with paper and plastic shim, so I made this to eliminate the chipping.
The Body is 17-4PH, the Foot is Brass 360 Half Hard, and the Calibration Dial on the bottom is 17-4 PH as well. It was fun to make.
It is pretty slick, but not totally my idea, it was modified from someone else's design.
Considering that you can touch tools within .0001 it is great for when you have to blend pocket floors and hold Tight Tolerances.
I can't take all the credit for this, but thanks.
Toby D.
"Imagination and Memory are but one thing, but for divers considerations have divers names"
Schwarzwald
www.refractotech.com
