586,051 active members*
3,590 visitors online*
    Jun 2021
    Post CNC Milling Machine margin error
    Hi, i have a cnc machine of gravotech is8000, and using nc studio V2, the problem im facing is that whenever i move the x axis it always moves 8mm further, and y moves 5 mm further.
    Can someone please help me with us.
    Regards
    Apr 2004
    5737
    Re: CNC Milling Machine margin error
    Have you got your steps per unit configured correctly? Does this overshoot always happen the same, no matter the distance it travels, or is it proportional? Does it happen with jog moves, or just moves commanded by g-code?
    Andrew Werby
    Website
    Quote Originally Posted by Jordan15 View Post
    Regards
    Need more detail descriptions to check, video will be helpful.
  1. Mori seiki MV Junior milling machine - OT 102 error
    By smulanskomips in forum Fanuc
    Last Post: 02-28-2020, 11:10 PM
  2. TH error for yasnac CNC milling machine
    By a_rezaei in forum Vertical Mill, Lathe Project Log
    Last Post: 09-23-2015, 04:12 PM
  3. CNC Milling Machine Packages and Bespoke CNC Milling Machines
    By worldofcnc in forum News Announcements
    Last Post: 05-27-2010, 02:20 PM
  4. Z return margin error
    By Shotout in forum Haas Mills
    Last Post: 10-15-2006, 04:05 PM
