603,348 active members*
3,906 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > CNC not drilling straight in G10
    Mar 2014
    Hi, I'm using a Uniline 2000 CNC drill machine.
    I am trying to drill straight holes with a 0.8mm drill into 10mm thick G10.
    I'm looking for the perimeters for it to go straight, I can get the holes though but just not straight, it tends to wonder when leaving the material, so the first holes going in are fine, just not at the exit.
    I have it close, but just can't get it exact. I have been using pecking to keep the tool as cool as possible as it drills.
    I have been ranging the feed parameter between 15-30 and the speed/RPM between 60-70.
    Mar 2014
    Bump
    Apr 2012
    90
    so you're feeding 15-30 what? you're spinning at 60-70rpms, do you mean sfm?
  1. drilling straight (not a social commentary)
    By ampedtech in forum MetalWork Discussion
    Last Post: 02-26-2013, 05:15 PM
  2. Straight Plunge/Drilling (3/4") diam bit application problem
    By c.fehringer in forum WoodWorking Topics
    Last Post: 04-24-2012, 01:48 AM
  3. Drilling Straight? Experienced Machinists Inquire Within
    By Cartierusm in forum MetalWork Discussion
    Last Post: 09-13-2010, 07:25 PM
  4. Hints on drilling straight??
    By gtrdude in forum Uncategorised MetalWorking Machines
    Last Post: 08-10-2004, 01:05 PM
