I was setting my cent 1 with the sls sofware up for networking but now the cnc wont load comes up with 003 error C:\cnc\cnc path not found does any one have any idea how to fix this
thanks adam
thanks adam
Its a good thing you backed up your parameters on floppy before you began any network configuration. Compare your old file "path.dat" found on the floppy with your new file "path.dat" that is in your control and post back here what you find. They both contain a handful of lines containing ascii text.
found I had erased a line in config.sys Dir thats whats good about milltronics they have tech support that will help those tech know the control inside and out not just some tech support service center that deals with 10 different OEM's
