587,980 active members*
3,931 visitors online*
Results 1 to 10 of 10
    Jun 2017
    119
    CNC Plasma - Start Machine Motion
    Hello.
    I am currently running a Hyperhterm Powermax 45xp in my cnc setup. I am running the standard CNC usb controller software and I am thinking about upgrading to TNG when I will start upgrading my table.
    However I was looking through my Operator Manual for my 45xp and noticed that I have access to a output on my machine which tells the Software that the Arc has been initiated and that the machine can start moving. I would like to implement this in my setup but I can't find any options for this in the CNC usb controller software.
    Is there an option for this in TNG or in CNC usb controller?
    I'm struggling with some missfires once in a while which is very annoying because I have to go back and find out excactly what hole was supposed to be done. Which can take a while if I'm cutting 3 or 5mm.
    Any help appreciated!
    Mar 2017
    1332
    Re: CNC Plasma - Start Machine Motion
    TNGv2 has an option to use "Arc OK" signal.
    Jun 2017
    119
    Under what tab is that located? Couldn't find it.
    Mar 2017
    1332
    Here
    Jun 2017
    119
    Great!
    I'm using the THC SD and not the 150, is that still ok? It won't affect anything right?
    Mar 2017
    1332
    It should work.
    Jun 2017
    119
    Ok great, I will give it a shot.
    How is the command/signal interpreted in the software though? It send signal to machine to start arc, then it pauses until it gets the arc ok signal? So "Pierce delay" timer is started after the software receives "arc ok" signal?
    Mar 2017
    1332
    In THC is enabled (G-Code M54P1) then motion commands will wait until ArcOK signal is present (assuming you use this pin).
    Jun 2017
    119
    Ok, so pin nr 1-8 = Input pin number?
    Hopefully it will work as I won't be using the 150 but the SD who regulates itself. It seems as if the 150 probably would have been a better choice atm.
    Mar 2017
    1332
    Yes, input pin.
  1. Replies: 0
    Last Post: 02-23-2019, 08:25 PM
  2. Replies: 0
    Last Post: 01-21-2019, 04:17 PM
  3. Replies: 1
    Last Post: 06-16-2014, 08:15 AM
  4. LDR Motion Systems new plasma pipe machine
    By dhelfter in forum News Announcements
    Last Post: 02-12-2012, 06:24 PM
  5. Plasma motion control box on the blink
    By aaronbee in forum Waterjet General Topics
    Last Post: 02-20-2010, 09:04 PM
