Re: CNC Project !! AMA25LV (G0704) Mill !!!!!!!
![Quote](images/misc/quote_icon.png)
Originally Posted by
onocyclone
I then used a DTI finger on the vice jaw and told the machine to move 0.635mm as I know that the indicator will move round to 5 on the indicator. It Is mathematically calculated so that is safe.
The machine moved slightly over the the 5 mark ( 0.6731mm). I calculated the error and it turned out to be 0.0254mm.
The above clearly shows that your calibration method is faulty. The error that you calculated is 4% (0.0254/0.635)
That equates to 4mm per 100mm travel. Clearly not correct.
If you want to calibrate the axis you'll need to do it over the full axis travel.
Cheers,
Peter
Homann Designs - http://www.homanndesigns.com/store
