588,548 active members*
5,057 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > CNC Project !! AMA25LV (G0704) Mill !!!!!!!
Page 7 of 28 5678917
Results 121 to 140 of 552
  1. #121
    Nov 2009
    4415
    Re: CNC Project !! AMA25LV (G0704) Mill !!!!!!!
    Depending on wireless might not be the best decision. IMO
    A lazy man does it twice.
  2. #122
    Sep 2014
    286
    Why not, interference ?
  3. #123
    Jan 2008
    1543
    I've got an old wireless keyboard that is subject to interference from my mill spindle.
  4. #124
    Nov 2009
    4415
    I just want the least amount of issues between me and the machine/EStop. I have the APP on my iphone and it lets me run the machine too, but I dont trust it. There is a small lag in communication. I ran a shuttle pro for years and really enjoyed it and its versatility (not its durability). I now run a iMach3 by VistaCNC. Very nice unit, solid and very well executed.
  5. #125
    Sep 2014
    286
    I've now fitted everything in my enclosure and hade a start on the wiring the only way I could fit the computer in there was to use a shelf bracket that the computer will sit on then 2 pull ties to stop it tilting on the brackets. I then pull tied the computer power supply to the computer . It works and that's all I'm concerned about
    Attachment 259490Attachment 259492Attachment 259494Click image for larger version.
  6. #126
    Sep 2014
    286
    I've been busy spending again today I've got the wireless keyboard/trackpad and a TV bracket so I can now get the TV on the wall and get busy with wiring up the motors
    Tomorrows game is wording up the little 4 pin sockets and recalibration the machine again slightly. I can now see the end is near
    If anyone is reading my build with intentions on doing the same I'm now in £2400
    A lot of money but endless opportunities and an ability to make money with it and make what ever you like.
    So more pics to keep you all entertained
    Attachment 259738Click image for larger version.
ID:	259740Click image for larger version.
ID:	259742Click image for larger version.
    Cheers,
  7. #127
    Sep 2014
    286
    I've now fitted an LED plate inside the head of the machine which lights the whole garage up!!
    I've wired the motors and switches up with very nice conduit and sockets. All I need to do is wire the other end of the sockets to the drivers and control board.
    Attachment 260324Attachment 260326
    I will be making a front plate when the machine is back in action to hose the E stop so it will hide the LED and focus the light
  8. #128
    Sep 2014
    286
    The machine is back in business !!
    Attachment 260720Attachment 260722Attachment 260724Click image for larger version.
    I just need to wire up the touch probe and that's me done
  9. #129
    Sep 2014
    286
    One thing I've noticed when machining things round is at 0, 90, 180, 360 degrees there are flat points. Little odd I think. What could this be ?
  10. #130
    Jun 2004
    6618
    Could be backlash I think. Mach 3 does have some settings that would help with that. Then again, I think when it's backlash, it's only flat on two sides. Hmmm?
    Lee
  11. #131
    Sep 2014
    286
    4
  12. #132
    Sep 2014
    286
    And the control board is scrap !!!!!! Little tip folks, don't connect ground to a common.
    Anyone know of a better replacement in the uk?
  13. #133
    Jun 2004
    6618
    Old Truimph's had positive ground systems. You would have been in luck in that case.
    I hate it for you. I killed my very first stepper drive with an uncovered motor wire that touched the case. Many of us have had our share of kills. Are you talking about the spindle motor drive or the steppers?
    Lee
  14. #134
    Sep 2014
    286
    Steppers
  15. #135
    Sep 2014
    286
  16. #136
    Nov 2009
    4415
    Now is the time for a good board. Try a PMDX or similar.
    I suggest a post in the electronics section or pm "Al the Man", he can guide you on the ground and common connections, however I dont think that was the cause.
  17. #137
    Jun 2004
    6618
    The more I think about it, ground to common should not have hurt anything. Fastest1 mentioned it and that seems reasonable. I read so many threads that I don't recall your setup. We can certainly help you troubleshoot the problem.
    Lee
  18. #138
    Feb 2006
    7063
    COMMON is NOT necessarily the same potential as GROUND. COMMON simply means a point that is shared across many connections. On some motor drivers, and BOBs, COMMON is jumper-selectable to either 0V, or 5V. COMMON should never be connected to GROUND unless you know it is the same potential. Otherwise, you could be shorting the output of a power supply, which can have undesirable results.
    Regards,
    Ray L.
  19. #139
    Nov 2009
    4415
    I dont understand the nuances of the electronics as Ray does. I do know that on my HCNC board, I couldnt stop noise issues until I tied the common into the star ground (where the ground from the power supply was also connected). I had tried almost everything prior, wire separation, caps, higher debounce levels. Nothing else helped. IIRC I was told a method of testing the ground potential prior. Though I think at the time I was so frustrated, I winged it and it worked. Most likely luck as I have let the magic smoke out more than once, I even tried inhaling it ;-) It created no magic that I can tell.
  20. #140
    Sep 2014
    286
    I got the board in the link, it sounds easy enough to setup. It even has a feed rate nob
  1. Yay! "Project Cecil" G0704 build has begun!
    By TroyO in forum Benchtop Machines
    Last Post: 03-31-2015, 09:29 PM
  2. Let's call this the Turnkey Project - G0704
    By bogiestl in forum Benchtop Machines
    Last Post: 01-30-2012, 08:11 AM
  3. g0704 - conversion project
    By dsdmax in forum Benchtop Machines
    Last Post: 03-02-2011, 04:03 AM
  4. g0704 - first mill - questions ....
    Last Post: 03-28-2010, 09:32 PM
  5. CNC milling machine project, Weiss WMD25 / Amadeal AMA25LV
    By carl0s in forum Uncategorised MetalWorking Machines
    Last Post: 02-20-2010, 12:47 AM
