588,385 active members*
4,867 visitors online*
Results 1 to 8 of 8
    Dec 2003
    128
    CNC recommended reading?
    Im just starting out and have quite a few ideas for a CNC lathe. Can anyone recommend sites/books that an help me with my design?
    Mar 2003
    2139
    You building a lathe of converting one?
    E
    I wish it wouldn't crash.
    Dec 2003
    128
    building
    have quite a few parts now. Extruded alum, motors, ball screws, etc. mostly collected from Ebay, and salvaged..
    Sep 2003
    10
    http://www.harborfreight.com/cpi/cta...emnumber=41648
    I was looking at that lathe at Menards yesterday and I was thinking how easy that would be to convert to cnc metal lathe.
    put some thk linear slides on the beds, fashion a x axis add steppers get a three jaw chuck.
    seems like this would save ton's of time.
    the one I looked at was also variable speed also.
    Bob
    Mar 2003
    2139
    I would be interested in the project. Pictures would be great if posible.
    Eric
    Nov 2003
    181
    It looks like a good idea. I have a mini lathe that I'd like to convert over to CNC so that I could make pens in mass production. It would probably be easier and cheaper to convert a lathe over to CNC than to make or convert a milling machine. You're only looking at a 2 axis stystem vs. a 3 or more axis system. Are you thinking of putting the linear rails right on the machine or putting on a seperate base and mount the linear rails to that. The only thing is to make it sturdy. looks like a good project.
    Dec 2003
    128
    I got a couple crude autocad drawings here somewhere. Ill try and find and post them.
    Mar 2003
    4826
    To avoid disappointment, IMO, buy a real metal lathe and convert it. There is plenty of functionality still, in the cross-slide/carriage assembly of a standard metal lathe, even when you go cnc.
    Don't forget the real life problems with coolant, chips and metal dust when turning. Linear ways would be difficult to protect, unless you place them on the "back wall" of the machine.
    Forces for turning are quite high, since the cutters are seldom razor sharp like your typical milling/routing cutters. Considerable force is exerted on all parts of the machine, the spindle, tailstock and the distance of the cutting action from your linear bearings, amounts to leverage working against your machine. Flimsy is no good.
    First you get good, then you get fast. Then grouchiness sets in.
  1. Using your CNC Mill as a CNC Lathe
    By lstool in forum Knee Vertical Mills
    Last Post: 06-12-2017, 02:29 PM
  2. Making money with CNC
    By Johnuk in forum Community Club House
    Last Post: 12-13-2009, 05:46 PM
  3. Newbie to CNC world
    By HighOctane in forum DIY CNC Router Table Machines
    Last Post: 01-25-2005, 08:58 PM
  4. CNC deviation error
    By Alex S.A in forum CNC Machine Related Electronics
    Last Post: 10-22-2004, 08:10 PM
  5. The start of a big CNC project...
    By UKRobotics in forum Uncategorised MetalWorking Machines
    Last Post: 09-30-2004, 11:34 PM
