588,565 active members*
5,015 visitors online*
Page 23 of 24 1321222324
Results 441 to 460 of 466
  1. #441
    ericks Guest
    Re: CNC router build
    Well...i was going to make my own vacuum table but like always too busy with other stuff. So my wife said ....honey just buy one, so i did. Shipping from Germany is just crazy expensive though. Hope it works well for the price i paid!! It's just the table so i still need to sort the valves and vacuum pump...
  2. #442
    ericks Guest
    I thought i would give a little feedback on the machine, now that i have been using it a lot. First the spindle motor is working great, the Sako drive is also performing very well. The machine itself is better than i ever expected....i still have to complete some work on the cabling and control panel. Reason for this delay is i am still deciding on e few things. The Aussie made bob is excellent....this is my choice from now on.
  3. #443
    ericks Guest
    My first ever youtube video...only to see how it would look/work
    https://youtu.be/rWYfDlQa0to
  4. #444
    Sep 2005
    1740
    Nice work and nice job on the wiring.
    Retired Master Electrician, HVAC/R Commercial. FLA Saturn 2 4x4 CNC Router Mach4 Kimber 1911 45ACP
  5. #445
    ericks Guest
    Thank you
  6. #446
    ericks Guest
    Looking at that unfinished/messy control panel it's now about time i finish all the wiring and tidy it up!
  7. #447
    ericks Guest
    Managed to tidy up the panel a bit. Hope to complete everything soon
  8. #448
    ericks Guest
    Made use of some bits of acrylic lying around and made the first terminal box for the x-axis stepper motor. Hope to do the other motors soon...
  9. #449
    Mar 2003
    35538
    How is it attached to the motor? Did you drill and tap the back plate?
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
  10. #450
    Oct 2009
    875
    I guess high temp double sided tape?
  11. #451
    Sep 2006
    6463
    Hi, you'll need a 3D printer to make those parts...….there's no end to the fun you can have.....it opens up a complete new World...….I've just been bitten by the plastic bullet so nothing is going to get done now.
    Ian.
  12. #452
    ericks Guest
    I used the existing two tapped holes, they had a tiny plastic bit holding the cable in place
  13. #453
    ericks Guest
    Quote Originally Posted by handlewanker View Post
    Ian.
    Hi...rather not, i don't have time to get into that too
  14. #454
    ericks Guest
    A better view of the inside of the boxes...
  15. #455
    ericks Guest
    Next step in the build will be to install brackets for the limits. For now i will add brackets but for version 2 of this machine it will be incorporated in the machine brackets. I have now had two guys asking me for a quote to build them a similar machine. Obviously they will get a neater and improved design....quoting and time to build is the challenge, my plan was to only build control panels for now due to time restraints
  16. #456
    Sep 2019
    197
    Decided to mount the vacuum table today. Hope to have it sorted this week
  17. #457
    Feb 2005
    829
    Nice work!
    Did you build that vacuum table or buy it? If bought where at and aproximatly how much?
  18. #458
    Sep 2019
    197
    Quote Originally Posted by nlancaster View Post
    Nice work!
    Thanks, i bought it from a supplier in Germany. I will have to check how much and from who i ordered it. I do remember shipping was crazy expensive
  19. #459
    Sep 2019
    197
    The company is called cnc-plus....i honestly cant remember what i paid, it was a while back
  20. #460
    Sep 2006
    6463
    Hi, what are you using for the vacuum part? …...I just "found" a vacuum cleaner, sans the suction hose, on a nature strip and it still runs.
    It's a Piranha Phantom model, 2,400 Watts and sucks like crazy.
    The vaccy is so quiet it's almost silent at 3 metres distance.
    They retail at about A$124.00 on EBAY.
    Ian.
  1. Router home build Australia. Solid steel build
    By 80gus in forum DIY CNC Router Table Machines
    Last Post: 05-03-2020, 09:24 AM
  2. Replies: 0
    Last Post: 10-30-2014, 01:17 PM
  3. Newbie - To build or not to build Router/Plasma Table
    By dfranks in forum Waterjet General Topics
    Last Post: 04-08-2011, 05:16 AM
  4. Building a CNC Router; by someone who can't build a CNC Router
    By Womble in forum DIY CNC Router Table Machines
    Last Post: 09-27-2008, 01:51 PM
