Greetings everyone, newbie here. I build pool cues as a hobby and would like to take it to the next level with inlays. This board is great and I've read a lot of the threads. Do you think a small CNC router would be good for this? I know a lot of cuemakers use CNC lathes and mills and I know of one that uses a high end Techno-Isel router. The cue would have to be held in an indexing device, like a spin index, in lieu of a 4th axis. That is no problem, but I am wondering if a small 1"-1.25" round workpiece will work in a router table like the small home made ones I've seen on this board. I believe it is just treated as a flat surface and the inlay pockets are cut flat bottomed. I think accuracy for inlays would need to be in the .002-.003 range. Do you guys get this kind of accuracy with your machines?
Look forward to hearing from you.
Thanks,
Todd L
