I am in the design phaze of my CNC router and have gotten as far as I can without educationg mtself further on some of the more basic elements and need some help even knowing what questions to ask at this point.
Machine specifications--known--As I understand it, Servos are better/more accurate, or report theur actual possition better then steppers, but on a well built machine steppers will do the job fine, and are a lot less expensive.
- 24" travel on X and Y with 6" travel on Z
- All Aluminum/steele construction for the machine
- Wood construction for the base (not shown )
- Nema 23 steppers
- Porter Cable Laminate trimmer
- Dual Slide Rails on all three axis.
I will include some images of the preliminary design after my questions. I have searched through this form trying to answer as many as I could before bugging you guys.That should get me further along, and I don't want this post to be TOO long lol. Please note in the images bellow that the triangular gussets are not shown, but I have made provisions for them. Also, some og the screw/bolt holes are not drawn in yet either as its a concept sketch.
- Lead Screws vrs. Ball Screws. As I understand it, the ball screws are more accurate/repeatable. I was thinking 1/2-10 lead screws or the equivelant ball screws, but I am not sure how to incorporate them into the design (there is a detail of the slide in the images below).
- How are the ends of the threadded rod where it exits the vertical (horizontal on Z of course) supports actually suspended? Are the ends machined to .25" dia so they ride on bearings pressed into the blocks?
- Limit/Home switches. It seems they are needed. Is any one type better? What is the most econimical choice? Who do you recomend?
Above is an overview image. The rectangular tube used for the Axis slides is 2" x 6" aluminum with .125" walls. I like this choice because it makes for a very stiff structural material, is light, and the enclosed design will help limit the rails exposure to debris. The flat stock is .5" aluminum.
More detailed view of the motor mounts for the Porter Cable Laminate trimmer. the backing plate for the Z head is shown as .25" but I will likely use .5" also, and include some triangular gusset braces.
The 2 images above show some of the details of the box beams. You can see how the rails will mount. Also, the end blocks that are bolted on are shown at .5" but I have already upgraded them to .75" to accomodate 5/16" X .75" screws to secure them in place on the box beams. I show the threaded rod being supported by a bearing, but as stated above, I am not sure this is how it is supposed to be done.
Above I have shown how the carriages (no idea what the correct term is) without the box beam so you can get an idea of how they are assembled. They are 6" wide to provide good stability and tesist rotational forces (rocking). The center bearing is 2" Dia Derlin type (ala Widget Master's excellent machine) though I am not sure if you can use them with ball screws, or how the ball screws are mounted/incerted at all for that matter.
The last 2 images give you an idea of how the cariages/slides work with the slots and mounting in the box beam. As a novice to CNC Routers, the design seems very capable structurally, (to me anyway). I will have slight recesses or pockets for the stand off's machined into both the carriage blocks, and the .5" up rights to ensure everything bolts together true.
I appreciate any help you guys can offer, and I WILL be building this machine. I have access to a large CNC router for cutting the flat parts, and the slots in the box beams--all I am waiting for is to lock the design down. I also intend to share a full step by step building log with excellent images and video to pass along whatever I learn.
Thanks for any help, and Happy Holidays to all of you =)
Geno
