588,183 active members*
4,170 visitors online*
Page 1 of 2 12
Results 1 to 20 of 24
    Oct 2003
    208
    Cnc Router table Plans and ideas
    Hi all.
    I am now working on a set of plans for a homemade CnC router.
    I want it to have a cutting area of 24" x 36". I am gonna use 175oz/in stepper motors.
    I am planning on using rails down the sides of the table for the Gantry to ride on the x - axis. The Gantry will have v-groove bearings to ride on the rail 2 on top of the rail and one below the rail.
    Anyone made a table this size?
    I would appreciate any ideas anyone can give me.
    I will post the plans as i can.
    Mar 2003
    2139
    My table is that size. Best of luck with the project!
    Eric
    I wish it wouldn't crash.
    Oct 2003
    208
    cool. My boss's name is Eric.
    Tell me about your table. The bearings and things you use.
    Mar 2003
    2139
    Have a look here. It's all there.
    http://www.cnczone.com/showthread.php?s=&threadid=646
    Eric
    Oct 2003
    208
    HERE IS THE TABLE AND GANTRY.
    Mar 2003
    2139
    What material will you use? MDF?
    Why is the table so tall?
    Looks nice so far!
    Eric
    Oct 2003
    208
    MATERIAL: Probably a combination of MDF and Plywood.
    Table Height: Thats just the way it came out. Its gonna have the drive screw going underneath the table in the middle.
    The gantry is gonna ride on rails on the outside of the table. With a V-groove bearing on top and bottom of the rail. That's why it came out so high.
    Aug 2003
    94
    What 3D program can i use to gram artworks? Any free ones?
    Sep 2003
    22
    Gantry Mounting
    Hey Little Joe,
    Just one comment..... if you put the linear rail on the upper side of your baseframe instead of the lower side it will reduce the sway in the gantry.
    Also, have a look at ChuckKnight's thread on his wood/mdf router. It has some good pictures and stuff.
    Eldon.
    Oct 2003
    208
    i can't find that thread.
    Sep 2003
    1113
    http://www.cnczone.com/showthread.php?s=&threadid=1212
    I think thats it
    Some great ideas and work in mdf
    :cheers: Jim
    Oct 2003
    208
    hi
    i got a project i need a cnc to do. i want to take some kitchen cabinet doors and do some inlay in them. kind of like intarsia.
    the cabinet doors are about 17" by 22"
    this is the intended purpose of the cnc i have posted here.
    does anyone have any possitive comments / suggestions?
    Mar 2003
    2139
    Looks good to me. Get some MDF and start cutting!
    Eric
    Aug 2003
    94
    does lowes carry MDF boardS?
    Sep 2003
    1475
    They sure do.
    Hager
    Apr 2003
    598
    At mine, it's in the same aisle as the plywood, at the edge of the lumber department. Easy to find.
    -- Chuck Knight
  17. #17
    Oct 2003
    208
    Cnc router table plans and ideas
    here is the latest revision to my plans.
    notice i moved the rails up. and also notice that i added the rail alignment blocks.
  18. #18
    Sep 2003
    1113
    Ljoe - I'll keep watching and waiting to hear/see how you handle the spindle/router between the rails on the y axis.
    Access to the collet and all were my concerns when I was considering a similar approach.
    It does look sturdy though!
    :cheers: Jim
  19. #19
    Sep 2003
    1475
    Joe,
    In some of my brain storming on paper I thought about a pivot up router. Using a hinge to pivot it up between the rails and a couple of wingnuts to lock it in the down position.
    Like I said it's brain storming, not necessarly good.
    Hager
  20. #20
    Sep 2003
    1475
    Joe,
    Good out of the box design.
    Currently the angle iron is mounted to ears on each side, It might be stronger to eleminate the ears and make the end pieces the same width all over. MDF doesn't have any grain like wood so it can brake.
    Hager
Page 1 of 2 12
  1. Poll: What Plans Do we Want Cheaply?
    By vacpress in forum Polls
    Last Post: 09-15-2015, 07:50 AM
  2. CNC Retrofits and plans
    By RickOmatic in forum News Announcements
    Last Post: 06-14-2005, 06:15 AM
  3. Someone have an working CNC Table Plans?
    By samsagaz in forum DIY CNC Router Table Machines
    Last Post: 03-26-2005, 05:34 AM
  4. My plasma table design
    By m_c in forum Waterjet General Topics
    Last Post: 07-24-2004, 07:01 PM
  5. Sanity check- 6'x10' table
    By Zephrant in forum DNC Problems and Solutions
    Last Post: 05-13-2003, 05:09 PM
