Hello everyone!
I have been lurking these forums for a while now and now I think I am ready to get started. I have a rough design started in my head, but I ultimately want to detail the whole thing in a CAD program. Before I get started, I would like some advice on certain topics from people more knowledge about them than myself. This thread will also serve as my build log and a means of keeping track of materials, links, prices, etc.
I will share a little background info with you all so you have a better idea of my capabilities. I have never undertaken a project of this magnitude before, nor have I any experience with woodworking or machining. What I do have going for me is theoretical knowledge. I am in the last year of a mechanical-based engineering degree (naval architecture), so I understand that lingo fairly well. Like I stated previously, I also have been lurking these forums for a while. I have picked up some CNC-specific lingo since then (ex. backlash), but I am sure I am ignorant to a lot yet.
My requirements are as follows:
- Low Cost (<$500, including motors)
- Approx. 1' x 2' cutting area
- Maximize Z-travel
- Accurate to at least 0.1mm
Based on these requirements, I have come up with some ideas on what I would like for each part of the build.
Construction Materials
First choice: MDF (local Home Depot or Kent ~$10/sheet)
Alternative: Aluminium Angle (local Home Depot or Kent ~$5/3ft(?))
Linear Rails
First Choice: Skate bearings bolted to aluminium angle, running on aluminium angle.
Alternative: Skate bearings bolted to aluminium angle, running on a metal rod.
30 Bearing 608ZZ 8x22x7 Shielded Grease Miniature Ball Bearings $9.95)
Power Transmission
First Choice: ACME Lead Screws (2 x
Enco - Guaranteed Lowest Prices on Machinery, Tools and Shop Supplies $24.90)
Alternative: Allthread Rod (local home Depot or Kent)
Motors, Drivers, Controller, etc
First choice: A 3-axis kit from ebay (
3 Axis NEMA 23 Stepper Motor Driver CNC Kit + Software | eBay $184.88)
Alternative: A 3-axis kit from Keling (
Page Title $379)
Thoughts on the above would be appreciated, but I am more concerned with a few other issues.
First, if I use MDF, what is the best way to make joins? Cross dowels seem to be the most obvious choice to me, but Enco does not seem to carry them. Since I will (most likely) be ordering ACME lead screws from them and I do not want to place multiple online orders, this eliminates cross dowels from the running. Although, I am intrigued by what I have seen here:
Step 2: Making the Connection, joint and would like to know if anyone can recommend that sort of join.
Second, I would like this CNC machine to be able to machine parts for my next CNC machine. Since my next one will likely be made from aluminium, I would prefer if this machine could handle that. Is this reasonable?
Third, metric vs standard? Given that I live in Canada, I obviously follow the metric system. However, cheap bolts, MDF sheets, aluminium angle, acme lead screws, etc are all imperial. Since I prefer not to mix and match (or convert everything to metric), I will probably just stick with imperial. Thoughts?
I'm sure I have countless more questions running around in the back of my mind, but these seem to be what is stopping me from finalizing a design.
