588,487 active members*
5,085 visitors online*
    Oct 2016
    CNC Simulator Pro
    Hi,I am new on this forum and an absolute newbie in CNC programing.Currently I am practicing in CNC simulator Pro.Is there a way to check the dimensions of processed workpiece to see if your code was good?I am using free version of CNC simulator.
    Sep 2006
    6463
    Re: CNC Simulator Pro
    Hi....I was going to walk this path with a simulator too as I'm new to CNC, but you can't really beat having the mill of your choice operating with the G code of your own.
    .I use a pointed wooden dowel in the spindle and a soft Polystyrene foam block marked with the points I want to test the G code on..........this is a safety feature and you can touch down on the foam with the wood dowel and see if the code produces the tool path you planned on........only in a 2D format, but as it's a learning curve for manual G code programming, the end result is simple and not a disaster if you make a wrong code move.
    A lot depends on if you intend to write your own code which is what I'm doing.
    A more complex program produced with CAM is a different matter as there are Z moves that a wooden stick won't be of any use for.
    Ian.
  1. 21M-B Simulator
    By Shoprag in forum Fanuc
    Last Post: 07-23-2013, 03:27 PM
  2. CNC Simulator
    By xairflyer in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-03-2012, 09:17 PM
  3. simulator
    By jrmach in forum BobCad-Cam
    Last Post: 06-05-2012, 07:10 PM
  4. cnc simulator
    By Radosl81 in forum Want To Buy...Need help!
    Last Post: 09-29-2008, 01:13 PM
  5. CNC Simulator
    By dfedwards3915 in forum Education - Teachers and Students Hangout
    Last Post: 05-24-2007, 04:52 AM
