588,385 active members*
5,194 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > CNC stutters while cutting contours with curves
Page 1 of 2 12
Results 1 to 20 of 29
    Jul 2008
    12
    I just finished my cnc builds and all is well except while cutting contours with curves, my cnc starts to stutter for lack of better words. The cnc works well while moving in the x or the y, but not both at the same time. I have cycled through all the dip switch settings on the 5056 driver, but still no luck. Everything works well while cutting long passes on the x while stepping over on the y. Could someone please help. Do I need a bigger power supply? Different drivers? I'm at a loss.
    Thanks, Steve
    570 oz steppers,
    36v 9a power supply
    5056 drivers
    Apr 2015
    82
    Re: CNC stutters while cutting contours with curves
    are you experiencing this while cutting long straight diagonal lines, or circles and arcs?
    sometimes something gets a little off on my code side and it will studder around corners, but then it will do fine everywhere else. this has nothing to do with the motors just my code most likely trying to achieve a high level of accuracy and making each corner a hundred little arcs which confuses mack3.
    Mar 2010
    813
    Do you have CV on in Mach?
    Apr 2009
    5516
    If you're using Mach, make sure it's not set to exact stop
    Jul 2008
    12
    Quote Originally Posted by jueston View Post
    sometimes something gets a little off on my code side and it will stutter around corners, but then it will do fine everywhere else. this has nothing to do with the motors just my code most likely trying to achieve a high level of accuracy and making each corner a hundred little arcs which confuses mack3.
    Here is what i noticed, When i change the current limit on the drivers, it get much worse. I am attempting to make Stratocaster guitar necks. The cnc performs flawlessly throught out the machining except for the last operation: cutting out the contour. There is a 3" arc at the end and that is where it has the most trouble. I probably have 100 hours on the cnc
    Dan911
    I'm not familiar with "CV"
    louieatienza
    I will check on the "exact stop setting"
    Thank you.
    Apr 2009
    5516
    You can set Mach3 to either exact stop or CV. For curves, CV usually beat. Also check look ahead setting.
    Jun 2012
    817
    Check the "look ahead" setting. Mine works best set at ~200 lines. If this is too short, the buffer runs out and you get choppy curves.
    Jul 2008
    12
    I have cv enabled. Look ahead set to 200. I have tried turning off cv and adding G64 to my code as someone suggested. Still no luck.
    Here is a link to a short vid of my cnc misbehaving:
    https://youtu.be/XE76b01N8Ec
    Any help is appreciated. Thanks, Steve.
    Apr 2009
    5516
    What's the CV angle setting set to? Also what CAM are you using?
    Jul 2008
    12
    Quote Originally Posted by louieatienza View Post
    Cv angle=0
    Mastercam x8
    Apr 2009
    5516
    Quote Originally Posted by stevep43 View Post
    Cv angle=0
    Mastercam x8
    Try a CV angle of 90. Mastercam X8... my God, what have we come to! If you can program MasterCam you should be able to figure this out!
    Jun 2012
    817
    When outputting the g-code, what post processor format are you using? Certain formats might be adding code that overrides your mach settings.
    Like:
    G08 P1 = Look ahead control ON
    G08 P0 = Look ahead control OFF
    You might want to look at your code to see if you can spot any thing suspicious.
    Aug 2009
    655
    Just to rule out things, the file doesn't consist of tiny lines rather than arcs or arcs with a million nodes? I've had both issues on files I've imported from other formats.
    Sent from my LG-D852 using Tapatalk
    In case anyone is wondering, I'm the twin of the other gfacer on cnczone...
    Jun 2014
    777
    Quote Originally Posted by gfacer2 View Post
    I get the same stuttering intermittently, one pass it will be fine the next it will do it in certain spots. People have suggested getting a better graphics card in pc, I'm not so sure this will help but will let you know when I've tried it.
    I've tested voltage at psu, my machine runs off both AC and DC, and both stay very stable during these moves so in my case not a power issue.
    Leads me to think it's code, motion controller or pc based.
    Apr 2009
    5516
    Shouldn't matter if CV is on and have decent look ahead. Unless maybe steps/unit is set ridiculously high because of excessive microstep resolution.
    Apr 2013
    1899
    ...unless you need to have it exact stop...
    That is what I use and that is what gives the best precision. Constant speed may not always be suitable.
  17. #17
    Apr 2013
    1899
    Do you mean the "clonk clonk" sound at 13 seconds mark? To my ears everything else sounds normal. The cutting of curves sound always different from cutting in straight lines.
  18. #18
    Jul 2008
    12
    Quote Originally Posted by A_Camera View Post
    No, not the sound at 13 seconds. It's more the way it travels around the curves. It's not very smooth and i get a very jagged edge on the contour.
  19. #19
    Feb 2009
    192
    CV=Constant Velocity
  20. #20
    Apr 2013
    1899
    Oh, I see. Well, in my opinion that's perfectly normal. It depends on how the G-code is written, and how the curves are generated. I include my own video, listen to the sound. When the letters are written, it sounds like yours and when the circles are drawn it sound like a whining. That's because the difference in the code and how the motors are used. Perfectly normal in my opinion.
    https://youtu.be/ItUOqsYaRB4
Page 1 of 2 12
  1. Replies: 4
    Last Post: 09-17-2021, 07:22 AM
  2. Replies: 1
    Last Post: 11-08-2011, 05:30 PM
  3. efficiently cutting curves
    By endgrainguy in forum G-Code Programing
    Last Post: 06-06-2008, 01:20 PM
  4. cutting curves, circle, radius?
    By _taz_ in forum Benchtop Machines
    Last Post: 02-08-2008, 06:57 PM
  5. problem in cutting curves
    By fawzy_mahmoud in forum Linear and Rotary Motion
    Last Post: 12-13-2006, 10:26 PM
