I am building a set of 10 2-cylinder 2 stroke engines and need some cylinders made. I have attached dxf files and can provide IGS files if necessary.
I need 20 made for the 10 engines. CRS will work.
What is a quote for 20?
Once the first order is complete - what would a second order later of 20 or 40 cost?
The CRITICAL dimension is the interior diameter of the cylinder. The piston is a turned, ground and polished (TGP) at .500 inches. The interior must be less than .4995 - I will hand hone the cylinders for a final fit.
I hope for 100-300 per year and build up from there - depends on sales.
Shipped to Ogden UT 84401
I will also need 20 pistons and 20 contra-pistons - drawings to come later. Basics are 1/2" diameter TGP, bottom milled out with endmill (just a plunge cut) and cross hole for connecting rod pin. Contra-piston is .376 length of 1/2" TGP with a groove cut on the outside. No drilling - just groove and cut to length.
Quote some or all.
I have hobby CNC equipment that I have been making prototypes with and need to ramp up production.
Jerry J
