603,348 active members*
2,398 visitors online*
Page 2 of 7 1234
Results 21 to 40 of 123
  1. #21
    Sep 2012
    1543
    I'd pay 10,000 for that. Excellent work!
  2. #22
    Feb 2009
    118
    Quote Originally Posted by ViperTX View Post
    Katran,
    Beautiful work and a beautiful workshop.
    What extrusions are you using for the z-axis. It looks like you are using 4 extrusions of the smooth variety, but unsure of the size.
    What are you using to hold the extrusions together....besides the front Mic6, the side and the top plate?
    Thanks for the great pictures.
    Paul
    You are right , there are 4 pieces of aluminum extrusion , 80mm x 80mm ,
    heavy , made by ITEM . They are hold together by those aluminum plates ,
    ( 1 in front , 2 at sides , 1 on top ) wich are bolted to each other too...
    Plus , the extrusions are conected with the base ... There are some pics of
    the structure around here , take a look there ...
  3. #23
    Feb 2009
    118
    First test ... X and Y axis movement at 3600mm/min .
    It can go to 6000 , but travels are small ( 280mm x 480mm )
    so there is no need ...
  4. #24
    May 2005
    35
    Very Nice.
    Keith.
  5. #25
    Dec 2011
    161
    Quote Originally Posted by katran View Post
    Heeeeeey sexy machines oop oop
    Nice job man, really nice and clean!
  6. #26
    Feb 2009
    118
    Thanks ... I apreciate feedback .
    hope to make Z axis test in few days ( motor and driver already
    arrived , have to go to post office to pick it up ... )
    After testing everything , I will break down the entire machine ,
    reassembly using ALL the bolts and nuts , align the axis , and make the
    cutting tests ( carbide endmill / aluminum ) . Only then will see the true
    performance of the mill ...
    more movies will be posted shortly ...
  7. #27
    Dec 2007
    2133
    I don't think I could ever get tired at looking at pics of the beaut mill your making Katran! Simply awesome job mate! Puts a lot of other efforts to shame.
    cheers,
    Ian
    It's rumoured that everytime someone buys a TB6560 based board, an engineer cries!
  8. #28
    May 2005
    3920
    You have certainly earned it. A very impressive machine, one can not complement it enough. Truly a thing of beauty.
    Nice!
    You have an interesting design in this machine, I'm sure many of us are waiting for the final build.
    Inspiration for the rest of us.
  9. #29
    Nov 2009
    4415
    Wonderful work as everyone else has eluded to.
    To say your shop was ever a mess is laughable. What are you making medical equipment? Electronics and therefore require a clean room? I bet you can't sleep if you leave a tool on the table. Great work.
    Hoss was asked to do a spindle deflection test of some form (its validity has been questioned but for simpletons like me it made sense) where he used a fish scale attached to the spindle, he applied a specific load and measured the deflection. He was asked because people were trying to compare the X3 to a G0704. I would like to see a similar test in your machine, just for a reference.
    No matter how many times I have modified this post it keeps running the paragraphs as a single sentence! It shows as paragraphs til I hit save. Tapatalk is POS most of the time. The price is right though.
    A lazy man does it twice.
  10. #30
    Feb 2009
    118
    O.K ..uh... first of all , thank you . It's nice to see that my work is apreciated
    I like building cnc machines , but I don't actualy use them ... much .
    I am not trying to make a living out of this , is just a good way to spend
    my free time ...
    I spent a lot of time and money to bring the shop as it is now ... but this
    shop is my only " island of solitude " , a place where I can do my thing
    in peace and quiet ... You have no idea how stressful is my job ( I am
    an air trafic controoller ) , so I need something to keep me sane ...
    Deflection test ? You lost me there brother ... Why ? How?
    What do you mean by " doing it correctly " ?
  11. #31
    Nov 2009
    4415
    B Rad and Bam have both been helpful at times even if they might be the same person. Though the validity of the test might be in question, if the test is done with similar parameters (spindle nose 5" off the table etc) I can make a conclusion of some form. Seems like somene told me a while ago that my fan idea wouldnt work. Hoss did me a favor because I asked him to, and he was prepared with all the necessary tooling and knowledge. IMO it worked. Now I am asking Katran to do a similar test. If you have a better way by all means let us know but until then I still want a test that has been applied to other machines the same way.
  12. #32
    Feb 2009
    118
    Uh ... so , what is the big fuss with this test ? If it is that important , I will do it ...no problem .
    It will absolutely deflect in some way , no question about it ... Maybe the column , or the spindle head ...
    I don't give a rat's ass about the actual result , does not matter to me .
  13. #33
    Apr 2009
    266
    i said it once, and i say it again... damn gorgeous machine... very inspiring!
    makes me wanna go take a trip to romania to see it in person...
    my first..."Big Ape" CNCRP 2448 Build Log
  14. #34
    Nov 2009
    4415
    Katran,
    Your build is great. The results of the requested tests are more out of curiousity. Having seen it done on a few machines I am familiar with, it would be interesting to see the differences. I cant imagine the test creating any issues on the machine, taking much time or special equipment. Just a few minutes of your time and a little patience. I learn so much more by seeing and doing than reading and trying to comprehend formulas, loads and stresses. I wont be offended either way.
  15. #35
    Apr 2009
    5516
    Quote Originally Posted by Fastest1 View Post
    Katran,
    LOL I have to agree that this fascination with a deflection test is a bit weird. If the man doesn't want to waste what little free time he has with minutia such as a "simple deflection test" so be it. Besides, with that beast of a spindle, anything that gets in its way will be decimated long before any "deflection" shows up!
    So if Katran is kind enough to take away from his leisure to humor people with a probably insignificant [to him at least] test then so be it.
  16. #36
    Feb 2009
    118
    Initial build/mokup it's about done ... All axis perform well , no glitches ...yet .
    I still need to organize cables , find a better spot for the computer ...
    The big problem now is protection . I need to cover the rails and screws
    with some sort of way covers ... Any hints ?
    Also , a new movie ... I'm no film maker , so please be gentle ...
    P.S .
    third part of movie shows rapids at 6000mm/min . I think I can go
    to 8000 , but I'm afraid ...
    P.P.S .
    Can anyone explain to me how to make that deflection test ? Thanks .
  17. #37
    Nov 2009
    4415
    Katran, Hoss and Xnaron both have them performing thee test on their respective threads and machines. Basically applying a side load to the spindle with a ratchet strap and using a fish scale to measure the load being applied.
    Regardless of any of the results of the above test. That machine is beautiful. Well thought out and executed. Take a bow!
  18. #38
    Feb 2009
    118
    I'm stuck 100km away from workshop for the next few days , I got bored ...
    I made some sketches for a cnc lathe that I wish to build ... I was thinking
    of using a BT30 cartridge from Tormach as a spindle ... Is that a good idea ?
    Maybe some gang tooling ? Turret system seems to be a bit complicated ...
    Here are some pics ...
    P.S. Design is " stolen " from existing topic ...here on cnczone . Hope that
    the user will not be upset by that ...
  19. #39
    Dec 2011
    161
    As i said, touché man, awesome job! As for the lathe thing, the gang tooling system is the easier way but, seen your capabilities, i encourage you to go for the turret style.
    Anyway, have you considered some way to protect the linear ways/ballscrew? IMHO, a nice sheetmetal covers would be the final touch to this masterpiece!
    Something like this, not the best but i think you get the idea http://www.cnczone.com/forums/vertic...ml#post1034230
  20. #40
    Aug 2004
    2849
    katran,
    The only thing I don't like is the linear rails being exposed. I would use something like a u shaped mount to place the linear rails and trucks underneath.
    I had a question about your nice looking mill. How would you tram the mill? I'm asking because of the number of extrusions you use for the vertical or z-axis. Do you have any dimensioned drawings of the mill?
    Thanks,
    Paul
Page 2 of 7 1234
  1. DIY aluminum vertical mill build
    By sergizmo in forum Vertical Mill, Lathe Project Log
    Last Post: 09-07-2015, 04:59 PM
  2. Replies: 0
    Last Post: 01-05-2013, 11:51 PM
  3. Looking to build a simple vertical mill
    By Crudeau in forum Benchtop Machines
    Last Post: 10-27-2012, 01:13 PM
  4. Custom CNC vertical Mill build T-Minus 24:00
    By cncgabe in forum Vertical Mill, Lathe Project Log
    Last Post: 03-31-2012, 02:18 AM
  5. Started build on CNC Mill. Lots of pics, sorry.
    By EvanZ in forum Uncategorised MetalWorking Machines
    Last Post: 02-17-2008, 02:24 PM
