603,308 active members*
2,839 visitors online*
    Jul 2022
    4
    cnc4pc-mpg-rapid
    I installed a cnc4pc 6 axis mpg pendant. using c22 board and matching ribbon cable. Plugged into port 3 of the warp9 ess. I am using mach4. 4.2.0.4612 my problem is when i select any axis it rapids in one direction until i turn off the selected axis. It's also a bit of a delay starting and stopping the rapid. What am I doing wrong? BTW I watched the youtube video. Is there a calibration?
    Jul 2022
    4
    Re: cnc4pc-mpg-rapid
    I finally figured it out with help with mach support. There were several items missing from the set-up instruction. It works great now!
  1. Hard Wire MPG vs usb MPG
    By sparkness in forum Avid CNC
    Last Post: 02-08-2018, 01:17 AM
  2. Replies: 38
    Last Post: 03-09-2015, 05:19 PM
  3. Replies: 1
    Last Post: 12-13-2014, 01:57 AM
  4. Replies: 9
    Last Post: 08-06-2014, 10:16 PM
  5. CNC4PC MPG pendent + C22 setup
    By happytriger2000 in forum Mach Software (ArtSoft software)
    Last Post: 05-02-2009, 03:46 PM
